Ten Commandments submitted
Digital moe
Post by Digital moe »
Have submitted the .tgz for the UK copy of The Ten Commanments.
fly_scuba
Re: Ten Commandments submitted
Post by fly_scuba »
Tonight - I bought the 4K Version of the Ten Commandments (Cecil B Demille) here in the USA. I installed the newest version of MakeMKV 1.16.3.
Here is what I got from the App:
Using LibreDrive mode (v06.2 id=7FA2657C7667)
Saved AACS dump file as D:/Videos/MKB20_v76_The_Ten_Commandments_F5A9.tgz
I attached the file here... What is my next step please?
(250.88 KiB) Downloaded 528 times
fly_scuba wrote: Wed Mar 31, 2021 1:55 am I attached the file here... What is my next step please?
viewtopic.php?f=12&t=24711
It is better to email that file to svq@makemkv.com. Only posting it here slows things down.
fly_scuba
Post by fly_scuba »
Thanks for the tip.. email with the attachment is sent!
I will put forth the idea that posting the NAME of the tgz file here is beneficial; The name generated is unique to the "batch" of disks, so it is simple to tell if someone has already submitted the file for your particular disk. The "_F5A9" would change if the version of the disk is different.
Woodstock wrote: Thu Apr 01, 2021 3:37 pm I will put forth the idea that posting the NAME of the tgz file here is beneficial; The name generated is unique to the "batch" of disks, so it is simple to tell if someone has already submitted the file for your particular disk. The "_F5A9" would change if the version of the disk is different.
I agree with that.
