MAKEMKV and Howards End
bpatt
Post by bpatt »
Running into an issue with the 2017 PBS Howards End DVD, chews on it for a little bit, and then presents a single small output choice, which is just a portion of what should show.
I've attached the full debug log for you experts, thanks in advance for any suggestions!
MakeMKV_log.txt
(18.06 KiB) Downloaded 550 times
bpatt
Re: MAKEMKV and Howards End
Post by bpatt »
I upgraded to MakeMKV 1.16.4. I only get a small portion of the mini-series, please see the screenshot here.
Screen Shot 2021-07-15 at 3.53.33 PM.png (155.06 KiB) Viewed 5803 times
And, here is what MakeMKV produces below, open to your suggestions, thanks!
MakeMKV v1.16.4 darwin(arm64-release) started
Debug logging enabled, log will be saved as /Users/bpatt/MakeMKV_log.txt
Optical drive "BD-RE HL-DT-ST BD-RE BH16NS40 1.05d" opened in OS access mode.
Title #3 was added (7 cell(s), 0:55:47)
Title #6 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 was added (1 cell(s), 0:19:05)
Title #15 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 was added (7 cell(s), 0:55:47)
Title #25 was added (7 cell(s), 0:55:47)
DEBUG: Code 10551311 at :m;@{f,V/9vKJS C:213142496
DEBUG: Code 0 at :m;@{f,V/9vKJS C:121274998
DEBUG: Code 0 at )7y)HUx~xoB_OTqz{):29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Cells 9-9 were removed from title end
Title #30 was added (7 cell(s), 0:55:47)
Title #35 was added (7 cell(s), 0:55:47)
Title #40 was added (7 cell(s), 0:55:47)
Title #45 was added (7 cell(s), 0:55:47)
Title #50 was added (7 cell(s), 0:55:47)
Title #55 was added (7 cell(s), 0:55:47)
Title #60 was added (7 cell(s), 0:55:47)
Title #65 was added (7 cell(s), 0:55:47)
Title #70 was added (7 cell(s), 0:55:47)
Title #75 was added (7 cell(s), 0:55:47)
Title #80 was added (7 cell(s), 0:55:47)
Title #85 was added (7 cell(s), 0:55:47)
Title 3 in VTS 9 is equal to title 3 and was skipped
