Why are my WH16NS60 drives dying?
DavidGA
#1 Post by DavidGA » Mon Mar 29, 2021 10:50 pm
So far, I'm on my third WH16NS60 drive, and this too is dying. They work for ripping ~50 discs, and then they all start dying in the same way. They make a horrible grinding noise trying to read the disc, and then eventually fail to do so, sometimes claiming that there is no disc in the drive even when there is.
This is the sound it makes: https://youtu.be/PJwwk6GAFfM
Are these drives all crap or is it just me? Am I killing them somehow? They've all been flashed with MK LibreDrive firmware, the last one to 1.03, and I use them with MakeMKV on Linux.
Re: Why are my WH16NS60 drives dying?
#2 Post by Billycar11 » Mon Mar 29, 2021 11:23 pm
they are crap and so are the asus ones
get a BU40N
DavidGA
#3 Post by DavidGA » Tue Mar 30, 2021 3:04 am
The BU40N is a slimline drive though, right? Wouldn't exactly fit well in my desktop PC case.
#4 Post by Woodstock » Tue Mar 30, 2021 3:40 am
They sell adapter trays for "full size" (5.25") drive bays that mount both a 2.5" or 3.5" hard drive (or SSD) and a slim line optical drive. Just something to consider.
#5 Post by dcoke22 » Tue Mar 30, 2021 7:12 am
Have you tried doing a cold boot of your system when the drive stops working? Not a reboot. You need to remove power from the drive so that the drive starts fresh.
DavidGA
#6 Post by DavidGA » Tue Mar 30, 2021 8:28 pm
I haven't, no, but I'll give that a try next time. Thanks for the tip.
jdiscman7
#7 Post by jdiscman7 » Sat May 22, 2021 4:33 pm
I just ran into this issue today, did you ever find a solution? I'm using an external OWC Mercury Pro enclosure connected to an iMac. I've unplugged power and USB from the enclosure, reseated everything, but no dice. Still have a bunch of 4K stuff that needs ingested :(
#8 Post by Billycar11 » Sat May 22, 2021 6:48 pm
The solution is get a BU40N
#9 Post by SamuriHL » Sun May 23, 2021 12:22 am
I have a question. All the people that have these dying NS60 drives....are you all enabling speed control? or have it set at all in the registry for these drives?
jdiscman7
#10 Post by jdiscman7 » Sun May 23, 2021 3:02 am
How is that set? I got my drive from Alex and I put it in an OWC enclosure and connected to my iMac. Is that something I set in MacOS, MakeMKV, or at a different layer?
#11 Post by Billycar11 » Sun May 23, 2021 5:56 am
i know your probably not looking for me to answer but
mine were all stock speed most had trouble with BD 66 and would read bd 100 fine the opposite what of you think would happen...
but there was a whole other subset of ones that could not even see bd 100s
#12 Post by SamuriHL » Sun May 23, 2021 3:56 pm
The only time my NS60's (I have 3 of them) stop reading discs at all is when I have speed control set. If I leave them alone, they don't "die". They do have issues reading triple layer discs. That I think is a given with these drives. I'm just curious if the people who say their drives are "dying" are using speed control or not.
jonghotti
#13 Post by jonghotti » Tue May 25, 2021 9:01 am
Billycar11 wrote:they are crap and so are the asus ones
get a BU40N
Give it rest Bill.
jonghotti
#14 Post by jonghotti » Tue May 25, 2021 9:02 am
Give it a rest Bill.
#15 Post by Billycar11 » Tue May 25, 2021 9:34 am
you can sell them to dont feel left out
