MakeMKV freezes if explorer is opened
jesse
#1 Post by jesse » Sun Mar 28, 2021 5:09 pm
Hi, I'm using Windows 10 Pro and an LG BU40N portable UHD player with custom firmware.
If I open My Computer or insert an SD card, MakeMKV stops reading the disc and doesn't start again.
Is that the normal way the program works?
Re: MakeMKV freezes if explorer is opened
#2 Post by Woodstock » Sun Mar 28, 2021 5:50 pm
No, it is not. However, depending on your Explorer settings, it may be taking control of the drive away from MakeMKV as it enumerates what changed in the system. Theory says it should give control back, but MakeMKV might time out while waiting. It gets worse if any of your devices are slow to respond... Like a network share that isn't there anymore.
jesse
#3 Post by jesse » Wed Mar 31, 2021 12:42 am
It only occurs for 4K UHD discs.
