Read Speed [SAFE]
AndrewJ
Read Speed [SAFE]
Post by AndrewJ »
I've noticed that I've started to see Read Speed [SAFE] displayed for short periods when using MakeMKV and was wondering what it means. I typically see it at the start when the read speed is below 2x but I've seen it when the speed was over 5x as well. It's not a problem or anything, I was just curious since I don't recall seeing it in older versions before.
Re: Read Speed [SAFE]
Direct from the developer I had the same question
mike admin wrote: The "indicator" is a new feature for a speed control. It is displayed when MakeMKV slows down to a minimum speed due to "safe zone" - either disc edge or layer transition. So you know the reason why read speed suddenly became slow. No changes in logic, only additional indicator staring from 1.16.1 .
easyrhino
Post by easyrhino »
ah, I was also wondering, thank you!
