DASPI kernel extension - post Catalina et al
WaldoTJ
Post by WaldoTJ » Fri Mar 26, 2021 2:53 pm
the 'Pinned" post at the top of the discussion on DASPI is locked, but last updated in 2011.
i have been trying to install the daspi_1.5.pkg on my macOS (Catalina 10.15.7) for a few days. it seems that somewhere around version 10.15.3 Apple decided that 3rd party kernel extensions were forbidden. they used to be somewhat tolerated by use of the command:
  • sudo nvram boot-args="kext-dev-mode=1"
but that behaviour is no longer permitted. i believe that, specifically, there is no longer a mechanism for a user process to alter the "/System" folder structure; even after authentication as an admin ID.
i USED TO be able to run with the daspi package installed and running, but i had installed it while my mac was running a much older version of macOS. unfortunately, i had to re-install from scratch yesterday and so far, this is the only package i cannot restore.
is this option truly no longer available?
is there any ongoing effort to convert from the Kernel Extensions model to the System Extension Alternatives one?
i am almost tempted to re-re-install from scratch - which begins with Yosemite - install daspi - THEN upgrade to Catalina.
Re: DASPI kernel extension - post Catalina et al
Post by Woodstock » Fri Mar 26, 2021 3:40 pm
Unless MakeMKV tells you it needs DASPI installed, do not install it.
