Ripping Discs 2 or more at a time
kfreeb
Post by kfreeb » Thu Mar 25, 2021 8:27 pm
I have a feature request, where if you are ripping more than one disc, (I rip 4 at once) it would be a great help if when opening additional instances of MakeMKV, once an MKV ripping window has opened, (and settled down) an you set the drive you would like that window to rip from, that drive remains locked to that window, (once a drive is manually selected.)
Also, It seems, that MakeMKV likes to scan through all drives drives. If a drive is currently ripping, (in use) is there a way for Make MKV to skip over that drive, rather than do what it is currently doing, which is to search the directory of a disc in that is in use, (being ripped by another window) causing the drive ripping to oscillate till if gets the directory info from the disc already being used by another rip window, then moving on to the next drive, till it arrives on the drive you would like to work with.
Mac OS X Mojave
Mac Studio M3 Ultra
96GB Memory
GPU 80 Core
CPU 24 Core
Sequoia 15.7.4
Re: Ripping Discs 2 or more at a time
Post by Woodstock » Thu Mar 25, 2021 10:04 pm
Regarding the feature request:
MakeMKV v1.9.5 (27.7.2015 )
	* Added ability lo lock a program instance to a single drive
