Cheers will attempt to try this later myself.ragico wrote: ↑Tue Mar 23, 2021 10:58 pmI did a factory reset and nothing changed regarding plex audio passthrough.DaMacFunkin wrote: ↑Tue Mar 23, 2021 1:12 pmI have had a rely from Ugoos advising HD passthrough audio should work in Plex with 0.4.0 firmware.DaMacFunkin wrote: ↑Tue Mar 23, 2021 5:55 amI reported this to Ugoos, they replied to check what version firmware I was on (0.4.0).
At least I’ve had a reply. Overall I’m happy with the Dolby Vision / TrueHD performance as long as the files are ripped correctly, hope they can fix the colour space issue for SD/HDR10.
They have asked me to do a factory reset then reinstall Plex, I won’t get a chance to look at this for a few days due to work.
Anybody else like to try it?
Firmware 0.40
Just a thought, are people using Plex from Playstore or latest beta?
