bedders
Post by bedders »
DaMacFunkin wrote:
Wed Mar 24, 2021 7:17 am
So just had a quick try with Plex beta.
Plex will pass TrueHD/Atmos from m2ts and HDR10 MKV but I can not for the life of me get it to trigger Dolby Vision on Ugoos 0.4.0. Added to this a Dolby Vision mkv will only play in HDR10 and stereo... My Plex is set to March frame rate, maybe that is the problem?
I have TV led processing enabled with my LGC9, I wonder if people that are triggering Dolby Vision have LLDV enabled?
Just for clarification the MKV files I tried work fine with patched Fandangos Kodi on the same device.
Thanks. Yes this makes sense and I read somewhere that Panasonic actually advertise Dolby Vision and HDR10+ Capabilities through a single custom EDID field which in the past has caused problems for other sources. I guess either Panasonic can fix their side but I don’t like the chances of this. Or Ugoos can fix to interpret Panasonic’s EDID. I don’t like the chances of this either since there’s so many other problems with DV playback that need to be fixed
bedders
Post by bedders »
ragico wrote:
Wed Mar 24, 2021 11:13 am
Exactly the same here with a Panasonic GZ2000 oled
Tried also enable/disable frame rate match, resolution match etc.
Tried Plex from playstore and latest beta/official builds.
No way to get DV with Hd audio passthrough
It works in Kodi Dv edition.
A fellow Panasonic owner! Do you also only get LLDV option in DV display settings on the Ugoos?
DaMacFunkin
Post by DaMacFunkin »
bedders wrote:
Thu Mar 25, 2021 2:52 am
Hi, like I said I had a similar problem with LG and newer Realtek chipsets, LG released firmware updates for it themselves, you may need Ugoos to elevate it to Amlogic to elevate it to Panasonic.
DennisTheMenace
Post by DennisTheMenace »
With the vimu media player every dolby vision movie works with frame rate switch and ac3 and dts passthrough without stability issues only truehd and dtshd and dtsx doesn't (stutter) . With passthrough off every movie plays perfectly. I really hope the kodi modder can stabilise that kodi mod. You can run the vimu player out of kodi if you want to, if you use the app xbmc wrapper.
Edit: Another strange thing is that I also have problems with the official kodi 19 version installed from the playstore with the ugoos am6 plus and newest beta firmware. Sometimes I have to start a hdr10 mkv file 3 or 4 times before it starts.
I don't have any issues if I use another player like vlc etc. :?:
ragico
Post by ragico »
"A fellow Panasonic owner! Do you also only get LLDV option in DV display settings on the Ugoos?"
Dolby Vision settings:
Dolby Vision enable low latency (YUV)
Dolby Vision disable
The Panasonic GZ series (2019) do not support Tv led as far as I know.
This feature has been introduced in 2020 HZ series.
By the way, I am waiting for an Oled LG CX in nest days and will report accordingly-
MOHAX777
Post by MOHAX777 »
RESET_9999 wrote:
Wed Mar 24, 2021 10:32 pm
At least now we know that plex on this device CAN bitstream TrueHD. Now I'm sure ugoos can fix everything.
But I'm not sure that, coz troubles in amlogic SDK.
Also I'am look fast at Exoplayer 2.13 sources code and not found using process DV-EL metadata in mkv-rips (profile 7) :? . So I think it use only RPU-metadata.
bobbymkV
Post by bobbymkV »
Ugoos owners, what method are you using to install the 0.4 firmware?
I'm following the OTA FIRMWARE GUIDE from this page (going to about menu and finding AM6_ota_0.4.0.zip) -- https://ugoos.com/firmware-upgrade-guid ... ic-devices
After reboot it's bringing me to recovery where it's failing the secure check. I've already re-downloaded and tried again.
Edit: Oof, I can't even get ethernet to work what the hell? My experience with this thing isn't off to a great start.
ArArdin
Post by ArArdin »
bobbymkV wrote:
Thu Mar 25, 2021 7:52 pm
Just got my AM6 Plus yesterday. Since then I've been trying my *ss off to install any OTA from USB stick. No dice. Everytime I got "bad file descriptor" error.
I wanted to try this dualboot thing so today I installed the CoreElec dualboot beta 0.4.0 from the Ugoos site (this is NOT an OTA file) by hooking up my Ugoos to the pc and running the USB burning tool that comes with the package. This went smoothly, no problems.
Same here. What you want to do is enable WiFi and the you can connect through ethernet. After that, WiFi can be disabled again.
bobbymkV
Post by bobbymkV »
ArArdin wrote:
Thu Mar 25, 2021 8:08 pm
Thanks for the tips, but still can't connect to ethernet. I've tried three different cables that were all working with the devices they were already connected to including my LG TV, OPPO, and Shield. Already close to packing this thing up and returning it to Walmart.
bobbymkV
Post by bobbymkV »
JFC rebooting several times did nothing, but of course physically unplugging the power and plugging it back in made the ethernet work. This device is going to be a rollercoast ride isn't it? :lol:
EDIT: LMAO that also fixed my issue with the OTA firmware not working. I ran it again with no changes and it just worked. I'm now on 0.4.0
ArArdin
Post by ArArdin »
Yeah, it's not exactly a friendly plug & play device. Since yesterday I still haven't figured out how to exactly set up NFS client in Android to work. Highly irritating. Please let me know if you succeed :lol:
The "Remote Control Buttons" app is worthless, leaving the remote itself rendered half useless. The buttons in the app in no way match the real buttons.
I must say, that CoreElec is fast & responsive as hell. But then there is a Dolby Vision problem, as I learn here. That's why I wanted to try out the dualboot.
[EDIT] Just read your edit. How did you succeed? Putting the OTA zipfile on USB stick and run update from file?
bobbymkV
Post by bobbymkV »
ArArdin wrote:
Thu Mar 25, 2021 9:07 pm
Yes, same method I was doing before. Putting the OTA zip on USB, going to the About-->System Update app.
Now does anyone have any tips for getting Fandango's DV Kodi to work? I have untrusted apps allowed and it keeps on failing for some reason. I'm assuming I should use aarch64, which worked fine on my Shield.
Edit: Maybe a dumb question, but do I need to install the Play Store version of Kodi first and then install Fandango's? I thought it was totally standalone, but maybe I'm wrong.
bobbymkV wrote:
Thu Mar 25, 2021 9:18 pm
yep , the 64x didn't work for me as well: I used the 32x version. You don't have to download it from the play store.
norrellmeister wrote:
Thu Mar 25, 2021 12:07 am
Also seeing some serious stability issues in basic use.
Exiting a movie in Plex usually leaves the HDMI in a broken state, where there is a black screen, but sound works. Repeatedly hitting the power button fixes it, usually.
Resolution switching and color mode switching are not reliable. Sometimes I don’t get into DV mode, sometimes I do. Sometimes DV mode or 1080p mode or HDR mode “sticks” after a movie.
Playing DV movies is not starting reliably. Sometimes it’s starting in SDR. Restarting fixes it.
sounds similar to my first hour with this device... Once I stopped playing with the colorspace settings, those issues didn't happen again.
bobbymkV
Post by bobbymkV »
You guys are lifesavers, thanks! At least I've got the basic setup done now. Think I might have a beer or four before I start working on this thing some more....
MOHAX777 wrote:
Thu Mar 25, 2021 4:05 pm
Exoplayer 2.13 is what plex use ?
FEL is processed , I checked the ending credits of power rangers in PLEX and it was bright white instead of grey.
The big problem is that you can't FF/ RW or skip through the movie because FEL becomes out of sync with the BL (ghosting visible). You can't even resume a movie.
