Paprika: The volume key is unknown for this disc
parrotperil
Post by parrotperil »
Opening files on harddrive at G:
Saved AACS dump file as C:\Users\Parrotperil/.MakeMKV/MKB_v4_Paprika_E2A8.tgz
DEBUG: Code 0 at :J[]=^l|ZM,.0)Sd:29396092
DEBUG: Code 0 at :J[]=^l|ZM,.0)Sd:29394850
I know it's unusual for non-UHD blu-rays to throw this error. Looking through keydb, it seems that the volume key is listed. I'm wondering if it might have something to do with the fact that makemkv is not detecting my blu-ray drive. It's a blu-ray/dvd drive taken from an old dell laptop and hooked up to my currect pc with a sata->usb cable. VLC will play blu-rays from the drive just fine, and windows detects it. I'm running it as admin, ransomware protection off, all that stuff but still no luck getting makemkv to recognize the drive. I successfully ripped a dvd with the same drive by manually selecting the file using MKV, the error above is what happens when I use makemkv to select MovieObject.bdmv on a blu ray disk.
parrotperil
Re: Paprika: The volume key is unknown for this disc
Fixed! In my case, the problem was the sata -> usb cable I was using. For whatever reason it was causing makemkv to not see the attached drive. Connecting the drive to my motherboard sata port and case power supply solved the problem.
