gcc -g -O2 -D_linux_ -DMMCCXTR=1 -DHAVE_BUILDINFO_H -Itmp -D_GNU_SOURCE -oout/mmccextr.full mmccextr/ccextractor.c mmccextr/lib_ccx/activity.c mmccextr/lib_ccx/ccx_common_char_encoding.c mmccextr/lib_ccx/ccx_common_common.c mmccextr/lib_ccx/ccx_common_constants.c mmccextr/lib_ccx/ccx_common_option.c mmccextr/lib_ccx/ccx_common_timing.c mmccextr/lib_ccx/ccx_decoders_608.c mmccextr/lib_ccx/ccx_decoders_common.c mmccextr/lib_ccx/ccx_demuxer.c mmccextr/lib_ccx/ccx_encoders_common.c mmccextr/lib_ccx/ccx_encoders_helpers.c mmccextr/lib_ccx/ccx_encoders_srt.c mmccextr/lib_ccx/file_functions.c mmccextr/lib_ccx/general_loop.c mmccextr/lib_ccx/lib_ccx.c mmccextr/lib_ccx/output.c mmccextr/lib_ccx/params.c mmccextr/lib_ccx/params_dump.c mmccextr/lib_ccx/sequencing.c mmccextr/lib_ccx/utility.c -lc \
-ffunction-sections -Wl,--gc-sections -Wl,-z,defs
/usr/bin/ld: /tmp/cc1wjJHf.o:/tmp/makemkv-oss-1.16.3/mmccextr/lib_ccx/../ccextractor.h:49: multiple definition of `signal_ctx'; /tmp/ccQ6LwHe.o:/tmp/makemkv-oss-1.16.3/mmccextr/ccextractor.h:49: first defined here
/usr/bin/ld: /tmp/cc1wjJHf.o:/tmp/makemkv-oss-1.16.3/mmccextr/lib_ccx/../ccextractor.h:48: multiple definition of `ccx_options'; /tmp/ccQ6LwHe.o:/tmp/makemkv-oss-1.16.3/mmccextr/ccextractor.h:48: first defined here
/usr/bin/ld: /tmp/ccdT5CJc.o:/tmp/makemkv-oss-1.16.3/mmccextr/lib_ccx/../ccextractor.h:49: multiple definition of `signal_ctx'; /tmp/ccQ6LwHe.o:/tmp/makemkv-oss-1.16.3/mmccextr/ccextractor.h:49: first defined here
/usr/bin/ld: /tmp/ccdT5CJc.o:/tmp/makemkv-oss-1.16.3/mmccextr/lib_ccx/../ccextractor.h:48: multiple definition of `ccx_options'; /tmp/ccQ6LwHe.o:/tmp/makemkv-oss-1.16.3/mmccextr/ccextractor.h:48: first defined here
/usr/bin/ld: /tmp/cco59g1e.o:/tmp/makemkv-oss-1.16.3/mmccextr/lib_ccx/../ccextractor.h:48: multiple definition of `ccx_options'; /tmp/ccQ6LwHe.o:/tmp/makemkv-oss-1.16.3/mmccextr/ccextractor.h:48: first defined here
/usr/bin/ld: /tmp/cco59g1e.o:/tmp/makemkv-oss-1.16.3/mmccextr/lib_ccx/../ccextractor.h:49: multiple definition of `signal_ctx'; /tmp/ccQ6LwHe.o:/tmp/makemkv-oss-1.16.3/mmccextr/ccextractor.h:49: first defined here
collect2: error: ld returned 1 exit status
make: *** [Makefile:115: out/mmccextr.full] Errore 1
Thanks for linking this info! I did not know it is caused by default -fno-common behavior change.
The oss package updated in-place with this patch integrated.
mike admin wrote: Fri Mar 19, 2021 1:32 pm
In the name of anyone packaging: Please don't do that. I just got a patch accepted against FreeBSD ports to update to 1.16.3 and now it fails to build on the official builders because they of course check filesize and checksum. As a result, packages will be completely unavailable until my next patch is accepted (which is hopefully pretty quick). Using checksums for upstream packages is common practice to detect any "tampering"
