Hey all,
I have a blueray drive that I patched a long while ago and I cannot remember if it will read 4k discs or not after I've patched it. Is there any way I can find out? This is what the drive shows up as in MakeMKV below. I don't have any 4k discs to try and was going to buy one but didn't want to buy it if this drive wouldn't work. Thank you!
Product: BD-RE BU40N
Revision: 1.03
Serial number:
Firmware version: 1.03
This drive read UHD discs?
Re: This drive read UHD discs?
Yes, that drive is ready for UHD.Allistah wrote: Mon Mar 22, 2021 3:15 am Hey all,
Revision: 1.03
Serial number:
Allistah
Awesome, thank you!
