Drive recommendations
horrorfiend666
Post by horrorfiend666 »
Looking for suggestions on what 4k uhd writer to get and would it support burning on a I7-2600k system
Re: Drive recommendations
There is a recommendation topic for UHD readers at the top of this forum.
If you want to WRITE UHD disks, then the "best drive" isn't one of the "best readers". If you need a BDXL writer, the Pioneer drives have high ratings. They just won't rip UHD disks.
