Play Bluray Disc on macOS 10.13.6 does not work with VLC
macritzuko
Post by macritzuko » Sat Mar 20, 2021 9:12 pm
Tested version:
VLC 3.0.12
https://get.videolan.org/vlc/3.0.12/mac ... ntel64.dmg
MakeMKV v1.16.3
https://www.makemkv.com/download/makemk ... .3_osx.dmg
OS version:
macOS 10.13.6 (17G14042)
Description the problem:
Bluray disc will not play. VLC always shows this error message: Blu-ray error Blu-ray disc is corrupted.
Additional info:
I use everything locally and have nothing configured on my Mac device all default setting.
Both software are under /Applications
Under MakeMKV preferences -> Integration VLC.app is activated. See screenshot.
Questions
What am I doing wrong? Is this a bug or what else do I need to set so I can play my bluray disc from the bluray drive? It is only a Full HD Bluray disc from 2013.
Does it work for you on macOS 10.13.6 (High Sierra) device?
