I have a Problem with the drive - It says there isn't a disc in the drive.
I already tried to flash it, this worked without failure messages - but the result is still the same. what am I missing here?
Thank you,
Stef
Problem with Asus BW-16D1HT
Re: Problem with Asus BW-16D1HT
Operating system or the drive is not finding the necessary information on the disk to determine that there is a disk in the drive. Flashing won't fix this, unless you are testing a UHD disk before flashing.
Start with a different disk. Still nothing?
stef738
yes, still nothing, no matter what kind of disc i use. just tested with an audio cd. in a different drive, this cd works well.
perhaps the drive is broken? I remember some strange noise some days ago.
I bought it in december. perhaps i should just send it back and get a new one?
Definitely broken if Windows can't even see a CD in it.
How old is the drive?stef738 wrote: Sat Mar 20, 2021 5:45 pm Hello,
Thank you,
Stef
stef738
bought it in december.How old is the drive?
But what is the build date says on the top if your drive is older than 2015 you bricked it
