LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Firedragon9000
#1 Post by Firedragon9000 » Sat Mar 20, 2021 5:15 am
I'm getting this error when trying to rip One Piece Collection 14 Disk 1.
MakeMKV v1.16.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Draks/MakeMKV_log.txt
Title #1 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 44-end were skipped due to cell commands (structure protection?)
Title #11 was added (43 cell(s), 2:44:59)
Cells 7-end were skipped due to cell commands (structure protection?)
Title #12 was added (6 cell(s), 0:23:33)
Cells 30-end were skipped due to cell commands (structure protection?)
Title #13 was added (29 cell(s), 2:26:13)
Saving 1 titles into directory B:/Video/One_Piece_S5_P6_D1
DEBUG: Code 0 at 5!QGBX!$d0NlbR9*H:213130237
DEBUG: Code 4294967295 at R-yQTqCIO4NWM5sElfp!F:29402164
DEBUG: Code 3 at pjHY+!P}o7~qNf&ti0{:121268788
DEBUG: Code 0 at pjHY+!P}o7~qNf&ti0{:121268673
DEBUG: Code 0 at R-yQTqCIO4NWM5sElfp!F:213137068
Failed to save title 0 to file B:/Video/One_Piece_S5_P6_D1/title_t00.mkv
0 titles saved, 1 failed
BatrozX
Re: LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
#2 Post by BatrozX » Fri May 07, 2021 5:18 am
I am having the exact same issue with Disk 1 of Season 5, Voyage 6. Which I wouldn't be surprised if it's the same copy since the collections are just a re-release of the voyages but in a bigger package.
Saving 1 titles into directory E:/Videos/Rips/One_Piece_S5_P6_D1
Failed to save title 0 to file E:/Videos/Rips/One_Piece_S5_P6_D1/title_t00.mkv
Literally identical except for the directory. If anyone can assist it would be greatly appreciated.
snintendog
#3 Post by snintendog » Sat Aug 07, 2021 3:31 am
getting this on a rerelease of Dragon ball season 4 as well will copy fine with out subtitles all six discs do this. Thinking this is a big eff up on Funimations part Iso puzzle rips the iso perfectly no issue so disks are not damaged.
EDIT:
Seems there was a new version of MakeMKV downloaded it seems to have fixed it on the Dragon ball disks
