DennisTheMenace
#4786 Post by DennisTheMenace » Fri Mar 19, 2021 2:45 pm
RESET_9999 wrote: Fri Mar 19, 2021 2:15 pm
NiCE77 wrote: Fri Mar 19, 2021 2:09 pm
Do not use Kodi. Plex and the factory Media Player app are stable.
Plex is not an option for me because I want lossless audio.
Does the media player app support lossless audio and DV ?
The ugoos video player don't work with mkv for me. But mp4 and .ts (ts profile 7 also sometimes buggy) worked.I use the kodi mod for mkv
I don't had tested plex
bedders
#4787 Post by bedders » Fri Mar 19, 2021 8:31 pm
DennisTheMenace wrote: Fri Mar 19, 2021 2:45 pm
What is your display and what options do you have available under Dolby Vision display settings?
DennisTheMenace
#4788 Post by DennisTheMenace » Fri Mar 19, 2021 8:43 pm
Lg c9
Dolby vision
Lldv Dolby Vision
Always on Dolby Vision
bedders
#4789 Post by bedders » Fri Mar 19, 2021 8:47 pm
DennisTheMenace wrote: Fri Mar 19, 2021 8:43 pm Lg c9
Dolby vision
Lldv Dolby Vision
And you have “Dolby vision enable” turned on correct? Not LLDV.
DennisTheMenace
#4790 Post by DennisTheMenace » Fri Mar 19, 2021 9:57 pm
bedders wrote: Fri Mar 19, 2021 8:47 pm
Dolby vision
Lldv Dolby Vision
Yes
bedders
#4791 Post by bedders » Fri Mar 19, 2021 10:02 pm
DennisTheMenace wrote: Fri Mar 19, 2021 9:57 pm
Dolby vision
Lldv Dolby Vision
Yes
Thanks. I also cannot play MKV with DV through the inbuilt player with LLDV. It works with modified Kodi. I wonder how others have it working on inbuilt player..
Edit: I’ve been told inbuilt player only supports DV with MP4. Not sure if this is correct, haven’t tried MP4 yet
Big-rome
#4792 Post by Big-rome » Sat Mar 20, 2021 12:07 am
Just ripped 1917 and after a little choppiness in the begining playback has been flawless.
#4793 Post by RESET_9999 » Sat Mar 20, 2021 12:11 am
I'm not able to trigger DV with mkv container on plex/ugoos... is there a special build that I need to sideload like Kodi?
I'm also getting 2.0 audio only...
For fun, I checked LLDV vs TV-LED and they both look pretty much the same to me(no big difference as Vincent showed on the oppo). I only checked one movie, one scene, so maybe the difference is not the same from one movie to another ?
https://screenshotcomparison.com/comparison/12104
bedders
#4794 Post by bedders » Sat Mar 20, 2021 1:51 am
RESET_9999 wrote: Sat Mar 20, 2021 12:11 am I'm not able to trigger DV with mkv container on plex/ugoos... is there a special build that I need to sideload like Kodi?
Interesting..
If you check the CPU usage between TV led and player led is there much difference?
lexyz
#4795 Post by lexyz » Sat Mar 20, 2021 3:16 am
RESET_9999 wrote: Sat Mar 20, 2021 12:11 am For fun, I checked LLDV vs TV-LED and they both look pretty much the same to me(no big difference as Vincent showed on the oppo). I only checked one movie, one scene, so maybe the difference is not the same from one movie to another ?
Check "Eagle" scene from SM UHD HDR Benchmark (around 6:34 time mark)
Pay attention to beak color
norrellmeister
#4796 Post by norrellmeister » Sat Mar 20, 2021 4:54 am
Gives your description, I think you might be transcoding. If Plex doesn’t think your system can handle the native audio, it will direct play the video and transcode the audio, which totally breaks DV. I spent half a day on this once on my Shield because ... I connected BT headphones and this issue broke my DV.
DaMacFunkin
#4797 Post by DaMacFunkin » Sat Mar 20, 2021 6:40 am
Tried a full movie last night on the Mininx/Ugoos - They live.
I did a straight rip with Makemkv and the FEL presentation and Atmos surround was a delight, really good.
Bugs... after about 10 minutes I had a screen resynch but the movie recovered, then again about 52 mins I had a resynch but after that it was slightly glitchy (frame skips) so I paused the movie and started it again and it was fine till the end of the movie.
On pressing stop it didn’t unload back to the Kodi interface (best guess Dolby decoder froze, seen this on other devices) until I long pressed the power button (idk).
Overall this is the device, if the manufacturers can officially support this project we will have a winner
NiCE77
#4798 Post by NiCE77 » Sat Mar 20, 2021 9:58 am
DaMacFunkin wrote: Sat Mar 20, 2021 6:40 am Tried a full movie last night on the Mininx/Ugoos - They live.
Try latest Vimu Player 8.90 from this page: https://4pda.ru/forum/index.php?showtopic=777309
DennisTheMenace
#4799 Post by DennisTheMenace » Sat Mar 20, 2021 12:41 pm
Hey that Player works really very well. I have some stuttering when I select a Dolby Atmos soundtrack, but that's doesn't really matter to me because I don't have a Atmos sound system.
Thanks for the tip :!:
Here are some other download links for that vimu player 8.90
https://a2zapk.xyz/wp/how-to-debug-andr ... lications/
#4800 Post by RESET_9999 » Sat Mar 20, 2021 6:02 pm
lexyz wrote: Sat Mar 20, 2021 3:16 am Check "Eagle" scene from SM UHD HDR Benchmark (around 6:34 time mark)
It sure seems to affect more the scenes where FEL adds a lot to the image and I guess FEL doesn't add much to the MI scene that I compared last night because there's indeed a noticeable difference in certain scenes of the SM disc. Especially the red flower frames where it's very noticeable. But not much different on some other scenes like in the Eagle one though. lldv seem to be slightly more saturated/darker.
eagle: https://screenshotcomparison.com/compar ... /picture:2
red flower: https://screenshotcomparison.com/comparison/12133
owl: https://screenshotcomparison.com/compar ... /picture:1
norrellmeister wrote: Sat Mar 20, 2021 4:54 am Gives your description, I think you might be transcoding. If Plex doesn’t think your system can handle the native audio, it will direct play the video and transcode the audio, which totally breaks DV. I spent half a day on this once on my Shield because ... I connected BT headphones and this issue broke my DV.
thank you. I'll check the audio settings in plex. I use the same plex server on the shield and there's is no audio transcoding
DV works with ts and mp4 files though.
EDIT:
yes, that's the problem. My DV MKVs have Atmos audio and plex try to transcode(because there is no ac3 core in truehd /mkv) so DV doesn't work indeed. If I select an AC3 track before playing the movie then DV is triggered. I'm still getting 2.0channel even though plex says direct play and as I said, same plex server on my pc that works with the shield.
DV works much better on plex... i hope they add lossless support there
