MakeMKV fails to start since 1.15.3
wtuppa
#1 Post by wtuppa » Sun Dec 13, 2020 2:39 pm
MakeMKV 1.15.3 failed to start, so tried new version 1.15.4. I only get a popup window with the title "MakeMKV BETA popup" and the text "Application failed to initialize". Reinstall of MakeMKV 1.15.2 works and is running.
I have a registered version of MakeMKV.
Regards
Walter
Re: MakeMKV fails to start since 1.15.3
#2 Post by Woodstock » Sun Dec 13, 2020 3:21 pm
Knowing the operating system you're trying this on would help. Then, if there are any messages in the OS logs about the failure to start, please post those.
wtuppa
#3 Post by wtuppa » Mon Dec 14, 2020 6:27 pm
I am using Windows 10.
I found no logs in the Event Log of Windows.
wtuppa
#4 Post by wtuppa » Mon Dec 14, 2020 6:31 pm
I am enabled debug log in version 1.15.2 and then installed 1.15.4. The only line in the debug log is:
Debug log started at Mon Dec 14 18:29:22 2020 , written by MakeMKV v1.15.4 win(x64-release)
wtuppa
#5 Post by wtuppa » Mon Dec 14, 2020 6:33 pm
Version 1.15.2 logs these messages if the program is only started and then closed:
Debug log started at Mon Dec 14 18:32:42 2020 , written by MakeMKV v1.15.2 win(x64-release)
001005:0000 MakeMKV v1.15.2 win(x64-release) gestartet
001004:0000 Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als file://C:\Users\Walter/MakeMKV_log.txt
WinCdArb=v1.0.0_tiny win(x64-release)
SDF v07d: HL-DT-ST_BDDVDRW_CH12NS30_1.02_211404241908_K9JG1MH1245
005075:0000 Die neue Version 1.15.4 ist unter http://www.makemkv.com/download/ als Download verfügbar.
Application exited at Mon Dec 14 18:32:53 2020
STawAlKa
#6 Post by STawAlKa » Fri Mar 19, 2021 4:04 pm
Hi everybody,
I'm also facing this issue. On every start I get a popup that says:
NO_ANSWER_FROM_MAKEMKVCON
Today I tried again with 1.16.3, but still the same issue. 1.14.5 is the last version I got run on my computer. I can't find logs for this. No errors seen while compiling and also no errors while installing. I also had the same issues using the snap-version from the "app store".
My system OS is a ZorinOS (Ubuntu / Debian based).
Any ideas how to fix? Some said it works after reinstalling, but after reinstalling MakeMKV and system (for other reasons) the only chance for me to use the software is at version 1.14.5...
regards
STawAlKa
wtuppa
#7 Post by wtuppa » Sat Mar 20, 2021 5:00 pm
do you a RAM disc? This was the problem for my installation. I am using Windows 10 (20H2).
After changing the temporary directory (Environment Variable TMP and TEMP) to SSD, it worked again.
A recent update of the RAM disc also solved the problem for me.
stevem49
#8 Post by stevem49 » Sat Mar 20, 2021 8:46 pm
I had removed an F: drive and there were env variables stored there. Resetting the env variables did the trick.
STawAlKa
#9 Post by STawAlKa » Sun Mar 28, 2021 6:49 pm
Hi again,
I just removed the installed files of the MakeMKV installation
sudo rm -r /usr/lib/libmakemkv.so.1 /usr/bin/makemkvcon /usr/bin/makemkv /usr/share/applications/makemkv.desktop /usr/share/MakeMKV
and now I tried to install via Snap.
sudo snap install makemkv
I got the version 1.16.1 and seems like it works! (The program starts...)
regards
STawAlKa
Hi everybody,
regards
STawAlKa
