Getting errors at section 15 of the BR "Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR"
irishrOy
#1 Post by irishrOy » Fri Mar 19, 2021 10:05 am
Hello guys!
Long story short: I have already copied the BR onto the PC as a .mkv-file ~1 year ago. Since then I compressed the movie and deleted the original file. Sadly I compressed the file wrongly and the video quality was very bad.
Now 1 year later I want to copy the BR onto the PC again, but it only copies half of the movie. The movie consists of section 1 & 15. It loads section 1, but has probems with section 15.
The funny thing is, the BR is still new (only read 2 times now), has 0 scratches and the BR-drive is still the same from last year. Nothing changed, but suddenly it cant read section 15, it seems. I have already polished the BR disc, set the "re read-attempts" to 8, but it still doesnt work.
Can anyone help me, maybe?
The log reads as follows:
Title #00003.mpls has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00002.mpls was added as title #0
File 00008.mpls was added as title #1
Title #00000.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00001.m2ts was added as title #2
Title #00002.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00004.m2ts was added as title #3
File 00005.m2ts was added as title #4
File 00006.m2ts was added as title #5
File 00007.m2ts was added as title #6
File 00008.m2ts was added as title #7
Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00015.m2ts' at offset '0'
DEBUG: Code 100864261 at ]8PztK'0td`)P05'q8:29394758
DEBUG: Code 0 at a5O5<U4vT[Sc2UdBn2:29393677
DEBUG: Code 0 at 215(`lu=<Q8SA)8\:29394988
DEBUG: Code 0 at MT]y5,{;?_1mL9*:29401635
DEBUG: Code 0 at fQBBRwh9d#b@m]:t:121248203
Title #00015.m2ts was skipped
Title #00018.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Encountered 18 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Re: Getting errors at section 15 of the BR "Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR"
#2 Post by dcoke22 » Fri Mar 19, 2021 1:25 pm
viewtopic.php?f=8&t=15055
As you probably know, that error means the drive failed to read the disc. There's nothing MakeMKV can do about that.
As a side note, have you considered keeping your 'original' rips?
philb1701
#3 Post by philb1701 » Tue Mar 30, 2021 11:34 pm
Which movie are you having issues with?
If I have successfully burned it into an mkv format, I can send it to you.
