bobbymkV
#4771 Post by bobbymkV » Thu Mar 18, 2021 10:08 pm
RESET_9999 wrote:
dysprosium wrote: Thu Mar 18, 2021 4:48 am With DV off, are you getting the correct colours now for the SDR/HDR10 test patterns? If so, it's something that should be easy for Ugoos to fix as bobby mentioned (match content colourspace with DV on).
Good news, both HDR10 and SDR modes are accurate in 12bits on the UGOOS. So this the best android device for HDR10/DV/SDR + lossless audio.
HDR10: https://slow.pics/c/n4HSSEyU
SDR: https://slow.pics/c/XGv9WNjm
Strange that SDR in 8bit 444 is not accurate because my HTPC and x700 are both accurate in 8bit or 12bit.
*likes post*
#4772 Post by RESET_9999 » Thu Mar 18, 2021 10:28 pm
bedders wrote: Thu Mar 18, 2021 9:29 pm For those with Ugoos or Minix with Ugoos 0.40 firmware, what options are you seeing in Dolby Vision display settings?
I only get:
- Dolby vision enable with low latency (YUV)
- Dolby vision disable
And Always on toggle
The reference to “low latency” makes me think it is player led not TV led. I have Panasonic GZ1000
sounds like your TV only support LLDV (player-led)
on my old Vizio TV (doesn't support lldv):
-Dolby Vision enable
-dolby vision disable
-always on
on my LG OLED TV:
-Dolby vision enable with low latency (YUV)
-always on
bobbymkV
#4773 Post by bobbymkV » Thu Mar 18, 2021 10:43 pm
It looks like the best options to contact Ugoos is support@ugoos.net, eugene@ugoos.net, and @UgoosLtd Twitter handle. I can certainly reach out, but what do we need to ask them to do technically? I think I have a grasp, but someone else should put words in my mouth to get the best result I think lol
https://ugoos.com/contact-us
bedders
#4774 Post by bedders » Fri Mar 19, 2021 12:40 am
RESET_9999 wrote: Thu Mar 18, 2021 10:28 pm
I only get:
-always on
on my LG OLED TV:
-always on
Thanks for confirming. I’m pretty confident my Panasonic supports TV led DV so I’m not sure why it’s not detecting correctly. I’ve tried different cables directly connected to TV as well as through AV receiver.
https://youtu.be/e_a77zJTrO4
10:33 Vincent says “LG and Panasonic with their TV led Dolby Vision”
#4775 Post by RESET_9999 » Fri Mar 19, 2021 1:17 am
bedders wrote: Fri Mar 19, 2021 12:40 am
Well, I don't know, tv-led works fine here on different 2 TVs.
At least with LLDV, you don't have to bother turning off DV for HDR10/SDR content like we have to do for TV-LED DV. I just checked LLDV on my LG TV and I'm getting 12bits in all modes.
bedders
#4776 Post by bedders » Fri Mar 19, 2021 3:16 am
RESET_9999 wrote: Fri Mar 19, 2021 1:17 am [quote=bedders post_id=106846 time=<a href="tel:1616114450">1616114450</a> user_id=37491]
[/quote]
True.. but I think TV led should be better for DV.
Anyone got a Ugoos or Minix connected to a Panasonic OLED who can check their Dolby Vision settings??
dysprosium
#4777 Post by dysprosium » Fri Mar 19, 2021 6:10 am
RESET_9999 wrote: Thu Mar 18, 2021 9:47 pm
Great, thanks for the test. So basically the problem as I understand it is:
With TV-led Dolby Vision turned on, the output is currently forced to:
  • SDR: 8-bit YCbCr444
  • HDR10: 8-bit YCbCr444
  • DV: 8-bit RGB
With TV-led Dolby Vision turned on, the output needs to be changed to:
  • SDR: 12-bit YCbCr422
  • HDR10: 12-bit YCbCr422
  • DV: 8-bit RGB
We have confirmed (with Dolby Vision off) that 8-bit YCbCr444 gives the wrong colours for SDR and HDR10, and 12-bit YCbCr422 gives the correct colours for SDR and HDR10. TV-led DV output is 8-bit RGB (as it should be) and gives the correct colours.
I'm not even sure why when TV-led Dolby Vision is turned on, SDR and HDR10 are forced to 8-bit YCbCr444, since when DV is activated it switches to 8-bit RGB anyway. Force DV always on seems to be working as intended and outputs everything in 8-bit RGB.
NiCE77
#4778 Post by NiCE77 » Fri Mar 19, 2021 6:12 am
I told you ;)
DaMacFunkin
#4779 Post by DaMacFunkin » Fri Mar 19, 2021 7:21 am
Sorry late to the party, received the Mininx and flashed the Ugoos firmware LATE last night, are we saying choosing TV-Led processing causes incorrect colours with HDR10 and SDR?
Why is that even a thing? TV led processing should only affect Dolby Vision, does HDR10 not pass through?
bedders
#4780 Post by bedders » Fri Mar 19, 2021 9:02 am
DaMacFunkin wrote: Fri Mar 19, 2021 7:21 am Sorry late to the party, received the Mininx and flashed the Ugoos firmware LATE last night, are we saying choosing TV-Led processing causes incorrect colours with HDR10 and SDR?
What TV do you have?
dysprosium
#4781 Post by dysprosium » Fri Mar 19, 2021 9:59 am
Yes, for some reason that's how it turns out. With DV off, you can choose the combination of output bit depth and chroma, and RESET_9999 has tested SDR/HDR10 content and found that at 12-bit 422 the output is accurate and at 8-bit 444 it's slightly inaccurate (other output bit depth/chroma combinations e.g. 10-bit 420 might also be accurate, we just don't have test results for those).
However, with TV-led DV on, for some reason SDR and HDR10 content is forcibly output at 8-bit YCbCr444, and you can't change the bit depth and chroma. HDR10 metadata still passes through, it's just that the output colour depth is 8-bit, and strangely even SDR content also has slightly incorrect colours. It doesn't really make any sense why SDR/HDR10 content is forced to be output at 8-bit YCbCr444, because when DV content is played, it changes to output 8-bit RGB anyway.
With LLDV on, all content (SDR/HDR10/DV) is locked to output at 12-bit YCbCr422. This is correct for LLDV content and (coincidentally?) SDR/HDR10 content too.
Without further information it seems like a bug or oversight, because it doesn't seem like there's any good reason to restrict the output bit depth/chroma for SDR/HDR10 content when TV-led DV is on (of course, DV content should still be restricted to 8-bit RGB). It should be easy for Ugoos to fix it. In the meantime, we can switch TV-led DV on and off to get the most accurate colours.
#4782 Post by RESET_9999 » Fri Mar 19, 2021 11:21 am
I should have said that this device is the best android device in terms of capabilities but definitely not for stability. Especially when you are used to the stability of the x700 and an HTPC.
Once you start changing the colorspace settings, the device becomes very very buggy(i have not really tested plex).
Sometimes:
- DV gives a black screen, rebooting fixes that,
- DV just won't trigger DV: it even tonemap profile5 to HDR10
- HDR10 trigger HDR but without any metadata: just 12bits 422 bt2020, nothing more.
I don't see how someone would use this device without an hdfury device to tell if your current mode is the right one.
profile 7 is also VERY unstable (freeze, stutter, tv goes black, audio dropout), sometimes you have to start the movie 4times before it plays correctly. Profile 5 seems stable.
Hopefully, things get better with future updates but as for right now, I will still use my x700.
lexyz
#4783 Post by lexyz » Fri Mar 19, 2021 11:32 am
RESET_9999 wrote: Fri Mar 19, 2021 11:21 am profile 7 is also VERY unstable (freeze, stutter, tv goes black, audio dropout), sometimes you have to start the movie 4times before it plays correctly.
P7 unstable for STDL mkv, ts or DTDL mp4?
#4784 Post by RESET_9999 » Fri Mar 19, 2021 12:06 pm
lexyz wrote: Fri Mar 19, 2021 11:32 am P7 unstable for STDL mkv, ts or DTDL mp4?
I only tested STDL mkv, some profile 5 mp4 and hdr10/sdr mkv in kodi .
#4785 Post by Manixx2020beyound » Fri Mar 19, 2021 12:25 pm
It would be really nice if we could convert
P7 bl.el.Rpu to propper profile 5 with the funky colors.
