Post by Manixx2020beyound » Thu Mar 18, 2021 2:20 pm
No it wasn’t graded darker that is my test file png @1000 nit
Not sure where that meta came from lol
Last edited by Manixx2020beyound on Thu Mar 18, 2021 3:29 pm, edited 1 time in total.
Post by RESET_9999 » Thu Mar 18, 2021 2:23 pm
Manixx2020beyound wrote: Thu Mar 18, 2021 2:20 pm No it wasn’t graded darker that is my test file @1000 nit
mmm, so you are getting different metadata from the HBO stream...
very strange, the metadata i posted is from the WEB-DL
Post by shawnc22 » Thu Mar 18, 2021 3:22 pm
RESET_9999 wrote: Thu Mar 18, 2021 2:23 pm
The HBO stream is in DV. Guessing the scene releases can’t properly capture DV from HBO yet.
Post by RESET_9999 » Thu Mar 18, 2021 3:30 pm
shawnc22 wrote: Thu Mar 18, 2021 3:22 pm The HBO stream is in DV. Guessing the scene releases can’t properly capture DV from HBO yet.
there are two HDR HBO stream: DV and HDR10. the scene can web-dl DV and HDR10, they both use the same Widevine L1 protection.
HDR10 web-dl:
Video
Format : HEVC
Format profile : Main 10@L5@Main
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 4 h 2 min
Bit rate : 17.5 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.088
Stream size : 29.6 GiB (94%)
Writing library : x265 3.4hy:[Linux][GCC 7.5.0][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=1 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=96 / keyint=96 / gop-lookahead=0 / bframes=3 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=4 / selective-sao=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=18000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / vbv-maxrate=24500 / vbv-bufsize=24500 / vbv-init=0.6 / vbv-end=0.6 / vbv-end-fr-adj=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=0 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1) / cll=597,122 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / no-concatenation / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 597 cd/m2
Maximum Frame-Average Light Level : 122 cd/m2
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 1.30 GiB (4%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Dolby Vision WEB-DL:
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 18.0 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.090
Stream size : 30.4 GiB (96%)
Encoding settings : cpuid=1111039 / frame-threads=1 / no-wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=96 / keyint=96 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=4 / selective-sao=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=3 / rc=abr / bitrate=18000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / vbv-maxrate=24500 / vbv-bufsize=24500 / vbv-init=0.6 / vbv-end=0.6 / vbv-end-fr-adj=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=1 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / no-concatenation / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0
Language : English
Default : Yes
Alternate group : 1
Encoded date : UTC 2021-03-18 14:44:14
Tagged date : UTC 2021-03-18 15:38:19
Color range : Full
Codec configuration box : hvcC+dvcC
Audio
Format : E-AC-3 JOC
Codec ID : ec-3
Bit rate : 768 kb/s
Maximum bit rate : 811 kb/s
Title : English
Language : English
Encoded date : UTC 2021-03-18 15:38:05
Complexity index : Not present / 16
quietvoid
Post by quietvoid » Thu Mar 18, 2021 3:42 pm
The Dolby Vision RPU also contains the same ST2086 HDR10 metadata inside.
So where is the 4000 from :?:
Post by RESET_9999 » Thu Mar 18, 2021 3:56 pm
quietvoid wrote: Thu Mar 18, 2021 3:42 pm The Dolby Vision RPU also contains the same ST2086 HDR10 metadata inside.
yep that's right, when I turn off DV on my x700 and play a profile 5 file, I get HDR10 playback with the metadata from the RPU which corresponds to the HDR10 counterpart. I will try justice league on my x700 tonight.
The metadata posted by manix are the one from the HDR10 stream on HBO..
it's not a DV to HDR10 conversion.
maybe the web-dl are fake ? notice how the HDR10 version is encoded with wrong Chroma subsampling type 1 instead of type 2
you cant really fake a DV release though... maybe other streaming platforms? this is a mystery
quietvoid
Post by quietvoid » Thu Mar 18, 2021 4:36 pm
Doesn't seem to be a different service, but maybe they do have multiple versions for different displays.
600 nits, 1000 nits, etc. are all possible targets for Dolby Vision.
That would explain how the MaxCLL is very close to the target..
Post by Manixx2020beyound » Thu Mar 18, 2021 4:45 pm
RESET_9999 wrote: Thu Mar 18, 2021 3:56 pm
Right now in hdr mode it plays in funky colors bt2020
Yes web dl meta was correct just triple checked after getting hdr version.
Last edited by Manixx2020beyound on Thu Mar 18, 2021 4:52 pm, edited 1 time in total.
Post by RESET_9999 » Thu Mar 18, 2021 4:52 pm
quietvoid wrote: Thu Mar 18, 2021 4:36 pm Doesn't seem to be a different service, but maybe they do have multiple versions for different displays.
Yes, that's possible and totally makes sense but I think it's from different streaming websites. It's available on Itunes India.
I know that most of the disney+ web-dl are actually from Hotstar India and not from Disney+ America.
The bitrate/metadata and quality are not the same (also theres no mediainfo x265 encoding settings visible on disney+ web-dl):
Disney+ stream is at 16mb/s and Hotstar 20mb/s but Disney plus is still in slightly higher quality: https://screenshotcomparison.com/comparison/12072
Post by RESET_9999 » Thu Mar 18, 2021 4:53 pm
Manixx2020beyound wrote: Thu Mar 18, 2021 4:45 pm Right now in hdr mode it plays in funky colors bt2020
wait what ? now the metadata match ??
funky colors: yep its a bug on HBO app Shield in 23.976 ... if you switch to 60hz, you should get the HDR10 stream.
Post by shawnc22 » Thu Mar 18, 2021 5:04 pm
RESET_9999 wrote: Thu Mar 18, 2021 4:53 pm
Funky colors only in HDR10? Or also DV on the app at 23.976?
Post by Manixx2020beyound » Thu Mar 18, 2021 5:12 pm
Only hdr10
Sometimes u get dv in the funky colors too happens with wonder & only on the shield tv
Apple a few occasions
It glitches switching to 60fps fixes that it try’s to play the dv file while it is still loaded by the hbo app so u get bt2020 12-422 funky colors no triggering,
Exit app reset no issue in dv mode I sometimes I switch the vertex2 back to hdr10 mode to get meta mean while still in the app so like I said dv file still loaded.
Last edited by Manixx2020beyound on Thu Mar 18, 2021 5:18 pm, edited 2 times in total.
Post by RESET_9999 » Thu Mar 18, 2021 5:16 pm
shawnc22 wrote: Thu Mar 18, 2021 5:04 pm Funky colors only in HDR10? Or also DV on the app at 23.976?
DV is fine but when you have an HDR10 only display and try to play HDR content in 23.976 on HBO, you get the DV stream with green and purple colors
bedders
Post by bedders » Thu Mar 18, 2021 9:29 pm
For those with Ugoos or Minix with Ugoos 0.40 firmware, what options are you seeing in Dolby Vision display settings?
I only get:
- Dolby vision enable with low latency (YUV)
- Dolby vision disable
And Always on toggle
The reference to “low latency” makes me think it is player led not TV led. I have Panasonic GZ1000
Post by RESET_9999 » Thu Mar 18, 2021 9:47 pm
dysprosium wrote: Thu Mar 18, 2021 4:48 am With DV off, are you getting the correct colours now for the SDR/HDR10 test patterns? If so, it's something that should be easy for Ugoos to fix as bobby mentioned (match content colourspace with DV on).
Good news, both HDR10 and SDR modes are accurate in 12bits on the UGOOS. So this the best android device for HDR10/DV/SDR + lossless audio.
HDR10: https://slow.pics/c/n4HSSEyU
SDR: https://slow.pics/c/XGv9WNjm
Strange that SDR in 8bit 444 is not accurate because my HTPC and x700 are both accurate in 8bit or 12bit.
