@Mike
I've updated MakeMKV to latest 1.16.2 version but I see many GUI localization errors
which disappear only if I select the English interface language.
No issues at all with the old version (1.16.1).
MakeMKV 1.16.2 translation --error--
Re: MakeMKV 1.16.2 translation --error--
Ouch. Buggy product...
All non-translated strings are displayed as "error" instead of English. Managed to miss that...
Thanks for reporting!
Nobody59
...and something else is different since 1.16.2. But I do not think that it is a bug. It is now always at every MakeMKV start two .tmp
files are written into the user tmp folder. One binary and one in text format.
It was always like that - one temp file for caching, and one for log file. They should auto-delete on program exit.Nobody59 wrote: Thu Mar 18, 2021 2:08 am ...and something else is different since 1.16.2. But I do not think that it is a bug. It is now always at every MakeMKV start two .tmp
Can you please elaborate?BeverlyGoodman wrote: Thu Mar 18, 2021 6:01 am None of the functions apart from dvd rom drive option works. New beta to fix this weird problem of navigation to already ripped decrypted dvd folders on Even so, that wouldn't explain the crashes with no disc loaded.
Nobody59
On my Win7/XP system the .tmp files are not deleted. At every startup new .tmp files are created withmike admin wrote: Thu Mar 18, 2021 10:33 am It was always like that - one temp file for caching, and one for log file. They should auto-delete on program exit.
possibly random numbers followed by ...-0.temp and ...-1.temp.
In other words: If I start 10 times in a row, there are 20 .tmp files with the same size.
After a short DVD ripping test, the .temp were not deleted too...
Fixed, 1.16.3 now available. Also, big thanks for the translation!TeddyRaspin wrote: Wed Mar 17, 2021 5:43 pm @Mike
TeddyRaspin
@Mike
Thanks a lot for the new version. It works like a charm.
