Is the Minix neo running Ugoos firmware a better buy hardware wise or are they the same build quality?bobbymkV wrote: Wed Mar 17, 2021 3:28 amUGOOS AM6 Plus (which has Amlogic S922X-J SoC)jayper wrote:Which Ugoos device are we purchasing?
DaMacFunkin
NiCE77
With Plex, the 23.976 works too and more DV format supports than Kodi (but no HD audio).RESET_9999 wrote: Tue Mar 16, 2021 11:22 pmthanks, will try that...mattmarsden wrote: Tue Mar 16, 2021 11:09 pm
Use the Kodi DV build and it will do all framerates correctly.
EDIT: yep 23.976 works with kodi .. phew!
NiCE77
Same, I have both.DaMacFunkin wrote: Wed Mar 17, 2021 6:05 amIs the Minix neo running Ugoos firmware a better buy hardware wise or are they the same build quality?bobbymkV wrote: Wed Mar 17, 2021 3:28 amUGOOS AM6 Plus (which has Amlogic S922X-J SoC)jayper wrote:Which Ugoos device are we purchasing?
deadchip12
Wait, hold up... So you mean this only works when that hard drive contains nothing but that movie's folders?RESET_9999 wrote: Wed Mar 17, 2021 3:13 amThis is the first thing I tried...shawnc22 wrote: Wed Mar 17, 2021 2:54 am You can just use the decrypted original folder back, too, then without any extra remuxing, no? Any way to possibly do this over the network or USB only?
you have to remux with tsmuxer. you can't keep the original structure with the menu.
Huge downside though, It only works if the folders are in the root of the USB drive(no network) so I don't think you can use this method with more than 1 movie on a drive. Can be handy for long movies that you can't usually FF when in TS container.
even though the folder is really named BDMV, the x700 sees it as an AVCHD structure:
baker99
Makes me wonder if there's a hacky way of having multiple films by building a structure with each film being a separate chapter (yes it would mess up chapters in each individual movie)RESET_9999 wrote: Wed Mar 17, 2021 3:13 amThis is the first thing I tried...shawnc22 wrote: Wed Mar 17, 2021 2:54 am You can just use the decrypted original folder back, too, then without any extra remuxing, no? Any way to possibly do this over the network or USB only?
you can have other files/folders in the hdd but only one bluray folder structure in the root will trigger DV.deadchip12 wrote: Wed Mar 17, 2021 7:26 am
jedd_ai
Any difference between Ugoos and Minix in terms of DV format support? Which one would you recommend,?NiCE77 wrote: Wed Mar 17, 2021 7:01 amSame, I have both.DaMacFunkin wrote: Wed Mar 17, 2021 6:05 amIs the Minix neo running Ugoos firmware a better buy hardware wise or are they the same build quality?
mattmarsden
Funnily enough I found the Minix loaded with the Ugoos 4.0 firmware to perform slightly better than the Ugoos when using Kodi in terms of stuttering after seeking. I've also found that running the DV mkv through mkvtoolnix after being created in MakeMKV makes it perform in terms of stuttering in Kodi. Hopefully of course all of these issues will be sorted in Kodi. So at the moment my recommendation is to get the Minix and load the Ugoos firmware on it!jedd_ai wrote: Wed Mar 17, 2021 12:45 pmAny difference between Ugoos and Minix in terms of DV format support? Which one would you recommend,?NiCE77 wrote: Wed Mar 17, 2021 7:01 amSame, I have both.DaMacFunkin wrote: Wed Mar 17, 2021 6:05 am
DaMacFunkin
Cheers Matt, sounds like a plan.mattmarsden wrote: Wed Mar 17, 2021 2:13 pmFunnily enough I found the Minix loaded with the Ugoos 4.0 firmware to perform slightly better than the Ugoos when using Kodi in terms of stuttering after seeking. I've also found that running the DV mkv through mkvtoolnix after being created in MakeMKV makes it perform in terms of stuttering in Kodi. Hopefully of course all of these issues will be sorted in Kodi. So at the moment my recommendation is to get the Minix and load the Ugoos firmware on it!
jedd_ai
Thanks.mattmarsden wrote: Wed Mar 17, 2021 2:13 pmFunnily enough I found the Minix loaded with the Ugoos 4.0 firmware to perform slightly better than the Ugoos when using Kodi in terms of stuttering after seeking. I've also found that running the DV mkv through mkvtoolnix after being created in MakeMKV makes it perform in terms of stuttering in Kodi. Hopefully of course all of these issues will be sorted in Kodi. So at the moment my recommendation is to get the Minix and load the Ugoos firmware on it!
magnetoeric
Great to hear that x700 plays DV from the bd structure
I had S6700 which also supported bd structure, but the screen used to freeze for few seconds while forwarding/rewinding. Does this mean it's better to go for sony? Unfortunately i can't purchase ugoos or minix at my place.
Big-rome
When using the minix, after I stop the Dolby vision movie and the Kodi gui shows up I see what looks like another refresh rate change. Also the same when I exit Kodi and go back to the android interface. Do you experience that?mattmarsden wrote: Wed Mar 17, 2021 2:13 pmFunnily enough I found the Minix loaded with the Ugoos 4.0 firmware to perform slightly better than the Ugoos when using Kodi in terms of stuttering after seeking. I've also found that running the DV mkv through mkvtoolnix after being created in MakeMKV makes it perform in terms of stuttering in Kodi. Hopefully of course all of these issues will be sorted in Kodi. So at the moment my recommendation is to get the Minix and load the Ugoos firmware on it!
Big-rome
For the guys with the minix, leave a comment here if you are interested in having Dolby vision in CoreELEC.
https://theminixforum.com/index.php?thr ... post-32157
DaMacFunkin
I thought Quietvoid said this wasn’t possible in Linux?Big-rome wrote: Wed Mar 17, 2021 6:37 pm For the guys with the minix, leave a comment here if you are interested in having Dolby vision in CoreELEC.
Big-rome
It’s possible now if someone built a 32 bit version of CoreELEC. The devs would rather a 64 bit Dolby Vision kernel module.DaMacFunkin wrote: Wed Mar 17, 2021 6:41 pmI thought Quietvoid said this wasn’t possible in Linux?Big-rome wrote: Wed Mar 17, 2021 6:37 pm For the guys with the minix, leave a comment here if you are interested in having Dolby vision in CoreELEC.
