DaMacFunkin
Post by DaMacFunkin »
bobbymkV wrote: Wed Mar 17, 2021 3:28 am
jayper wrote:Which Ugoos device are we purchasing?
UGOOS AM6 Plus (which has Amlogic S922X-J SoC)
Is the Minix neo running Ugoos firmware a better buy hardware wise or are they the same build quality?
NiCE77
Post by NiCE77 »
RESET_9999 wrote: Tue Mar 16, 2021 11:22 pm
mattmarsden wrote: Tue Mar 16, 2021 11:09 pm
Use the Kodi DV build and it will do all framerates correctly.
thanks, will try that...
EDIT: yep 23.976 works with kodi .. phew!
With Plex, the 23.976 works too and more DV format supports than Kodi (but no HD audio).
NiCE77
Post by NiCE77 »
DaMacFunkin wrote: Wed Mar 17, 2021 6:05 am
Same, I have both.
deadchip12
Post by deadchip12 »
RESET_9999 wrote: Wed Mar 17, 2021 3:13 am
shawnc22 wrote: Wed Mar 17, 2021 2:54 am You can just use the decrypted original folder back, too, then without any extra remuxing, no? Any way to possibly do this over the network or USB only?
This is the first thing I tried... :)
you have to remux with tsmuxer. you can't keep the original structure with the menu.
Huge downside though, It only works if the folders are in the root of the USB drive(no network) so I don't think you can use this method with more than 1 movie on a drive. Can be handy for long movies that you can't usually FF when in TS container.
even though the folder is really named BDMV, the x700 sees it as an AVCHD structure:
Wait, hold up... So you mean this only works when that hard drive contains nothing but that movie's folders?
baker99
Post by baker99 »
Makes me wonder if there's a hacky way of having multiple films by building a structure with each film being a separate chapter (yes it would mess up chapters in each individual movie)
deadchip12 wrote: Wed Mar 17, 2021 7:26 am
you can have other files/folders in the hdd but only one bluray folder structure in the root will trigger DV.
jedd_ai
Post by jedd_ai »
NiCE77 wrote: Wed Mar 17, 2021 7:01 am
bobbymkV wrote: Wed Mar 17, 2021 3:28 am UGOOS AM6 Plus (which has Amlogic S922X-J SoC)
Same, I have both.
Any difference between Ugoos and Minix in terms of DV format support? Which one would you recommend,?
mattmarsden
Post by mattmarsden »
jedd_ai wrote: Wed Mar 17, 2021 12:45 pm
Same, I have both.
Funnily enough I found the Minix loaded with the Ugoos 4.0 firmware to perform slightly better than the Ugoos when using Kodi in terms of stuttering after seeking. I've also found that running the DV mkv through mkvtoolnix after being created in MakeMKV makes it perform in terms of stuttering in Kodi. Hopefully of course all of these issues will be sorted in Kodi. So at the moment my recommendation is to get the Minix and load the Ugoos firmware on it!
DaMacFunkin
mattmarsden wrote: Wed Mar 17, 2021 2:13 pm
Same, I have both.
Cheers Matt, sounds like a plan.
jedd_ai
Post by jedd_ai »
Same, I have both.
Thanks.
magnetoeric
Post by magnetoeric »
Great to hear that x700 plays DV from the bd structure :D I had S6700 which also supported bd structure, but the screen used to freeze for few seconds while forwarding/rewinding. Does this mean it's better to go for sony? Unfortunately i can't purchase ugoos or minix at my place.
Big-rome
Post by Big-rome »
Same, I have both.
recommend,?
When using the minix, after I stop the Dolby vision movie and the Kodi gui shows up I see what looks like another refresh rate change. Also the same when I exit Kodi and go back to the android interface. Do you experience that?
Big-rome
Post by Big-rome »
For the guys with the minix, leave a comment here if you are interested in having Dolby vision in CoreELEC.
https://theminixforum.com/index.php?thr ... post-32157
DaMacFunkin
Big-rome wrote: Wed Mar 17, 2021 6:37 pm For the guys with the minix, leave a comment here if you are interested in having Dolby vision in CoreELEC.
I thought Quietvoid said this wasn’t possible in Linux?
Big-rome
Post by Big-rome »
DaMacFunkin wrote: Wed Mar 17, 2021 6:41 pm
It’s possible now if someone built a 32 bit version of CoreELEC. The devs would rather a 64 bit Dolby Vision kernel module.
