deadchip12
#4711 Post by deadchip12 » Wed Mar 17, 2021 2:33 am
RESET_9999 wrote:
Wed Mar 17, 2021 2:32 am
deadchip12 wrote:
Wed Mar 17, 2021 2:15 am
What if the movie is already in bdmv structure, then which files do we put in tsmuxer?
you drag and drop the correct mpls file into tsmuxer and create a new bluray structure.
Awesome. Thanks.
jayper
#4712 Post by jayper » Wed Mar 17, 2021 2:45 am
Awesome. Thanks.
Holy shit, this is great news. Thank you for sharing!
jayper
#4713 Post by jayper » Wed Mar 17, 2021 2:46 am
Which Ugoos device are we purchasing?
#4714 Post by shawnc22 » Wed Mar 17, 2021 2:54 am
You can just use the decrypted original folder back, too, then without any extra remuxing, no? Any way to possibly do this over the network or USB only?
mulucy
#4715 Post by mulucy » Wed Mar 17, 2021 3:09 am
Awesome. Thanks.
Can confirm it works and it's awesome to have an untouched blu-ray folder structure! I tested with Mission Impossible Fallout and it worked perfectly with no hiccups or freezes. FF, chapters, and everything else are smooth and super fast! Great discovery!
mulucy
#4716 Post by mulucy » Wed Mar 17, 2021 3:12 am
I tried Mission Impossible Fallout with the remuxing method and it worked perfectly. But now that you mentioned this, I am wondering if what you are saying can also work. It seems easier to drag and drop a decrypted folder versus going through Tsmuxer.
#4717 Post by RESET_9999 » Wed Mar 17, 2021 3:13 am
This is the first thing I tried... :)
you have to remux with tsmuxer. you can't keep the original structure with the menu.
Huge downside though, It only works if the folders are in the root of the USB drive(no network) so I don't think you can use this method with more than 1 movie on a drive. Can be handy for long movies that you can't usually FF when in TS container.
even though the folder is really named BDMV, the x700 sees it as an AVCHD structure:
mulucy
#4718 Post by mulucy » Wed Mar 17, 2021 3:18 am
Huge downside though, It only works if the folders are in the root of the USB drive so I don't think you can use this method with more than 1 movie on a drive. Can be handy for long movies that you can't usually FF when in TS container.
I wonder why the Blu-Ray community has not hacked the Sony X700 player. It seems like a very capable player. It handles pretty much anything you throw at it ( except the MKV since its something new and I doubt it will ever support it )
bobbymkV
#4719 Post by bobbymkV » Wed Mar 17, 2021 3:28 am
jayper wrote:Which Ugoos device are we purchasing?
UGOOS AM6 Plus (which has Amlogic S922X-J SoC)
DaMacFunkin
#4720 Post by DaMacFunkin » Wed Mar 17, 2021 6:05 am
Is the Minix neo running Ugoos firmware a better buy hardware wise or are they the same build quality?
NiCE77
#4721 Post by NiCE77 » Wed Mar 17, 2021 6:59 am
RESET_9999 wrote:
Tue Mar 16, 2021 11:22 pm
mattmarsden wrote:
Tue Mar 16, 2021 11:09 pm
Use the Kodi DV build and it will do all framerates correctly.
thanks, will try that...
EDIT: yep 23.976 works with kodi .. phew!
With Plex, the 23.976 works too and more DV format supports than Kodi (but no HD audio).
NiCE77
#4722 Post by NiCE77 » Wed Mar 17, 2021 7:01 am
Same, I have both.
deadchip12
#4723 Post by deadchip12 » Wed Mar 17, 2021 7:26 am
Wait, hold up... So you mean this only works when that hard drive contains nothing but that movie's folders?
baker99
#4724 Post by baker99 » Wed Mar 17, 2021 9:01 am
Makes me wonder if there's a hacky way of having multiple films by building a structure with each film being a separate chapter (yes it would mess up chapters in each individual movie)
#4725 Post by RESET_9999 » Wed Mar 17, 2021 10:47 am
you can have other files/folders in the hdd but only one bluray folder structure in the root will trigger DV.
