jayper
Post by jayper »
deadchip12 wrote:
Wed Mar 17, 2021 2:33 am
RESET_9999 wrote:
Wed Mar 17, 2021 2:32 am
deadchip12 wrote:
Wed Mar 17, 2021 2:15 am
What if the movie is already in bdmv structure, then which files do we put in tsmuxer?
you drag and drop the correct mpls file into tsmuxer and create a new bluray structure.
Awesome. Thanks.
Holy shit, this is great news. Thank you for sharing!
jayper
Post by jayper »
Which Ugoos device are we purchasing?
Post by shawnc22 »
You can just use the decrypted original folder back, too, then without any extra remuxing, no? Any way to possibly do this over the network or USB only?
mulucy
Post by mulucy »
Awesome. Thanks.
Can confirm it works and it's awesome to have an untouched blu-ray folder structure! I tested with Mission Impossible Fallout and it worked perfectly with no hiccups or freezes. FF, chapters, and everything else are smooth and super fast! Great discovery!
mulucy
Post by mulucy »
shawnc22 wrote:
Wed Mar 17, 2021 2:54 am
I tried Mission Impossible Fallout with the remuxing method and it worked perfectly. But now that you mentioned this, I am wondering if what you are saying can also work. It seems easier to drag and drop a decrypted folder versus going through Tsmuxer.
This is the first thing I tried... :)
you have to remux with tsmuxer. you can't keep the original structure with the menu.
Huge downside though, It only works if the folders are in the root of the USB drive(no network) so I don't think you can use this method with more than 1 movie on a drive. Can be handy for long movies that you can't usually FF when in TS container.
even though the folder is really named BDMV, the x700 sees it as an AVCHD structure:
mulucy
Post by mulucy »
RESET_9999 wrote:
Wed Mar 17, 2021 3:13 am
Huge downside though, It only works if the folders are in the root of the USB drive so I don't think you can use this method with more than 1 movie on a drive. Can be handy for long movies that you can't usually FF when in TS container.
I wonder why the Blu-Ray community has not hacked the Sony X700 player. It seems like a very capable player. It handles pretty much anything you throw at it ( except the MKV since its something new and I doubt it will ever support it )
bobbymkV
Post by bobbymkV »
jayper wrote:Which Ugoos device are we purchasing?
UGOOS AM6 Plus (which has Amlogic S922X-J SoC)
DaMacFunkin
Post by DaMacFunkin »
bobbymkV wrote:
Wed Mar 17, 2021 3:28 am
Is the Minix neo running Ugoos firmware a better buy hardware wise or are they the same build quality?
NiCE77
Post by NiCE77 »
RESET_9999 wrote:
Tue Mar 16, 2021 11:22 pm
mattmarsden wrote:
Tue Mar 16, 2021 11:09 pm
Use the Kodi DV build and it will do all framerates correctly.
thanks, will try that...
EDIT: yep 23.976 works with kodi .. phew!
With Plex, the 23.976 works too and more DV format supports than Kodi (but no HD audio).
NiCE77
Post by NiCE77 »
DaMacFunkin wrote:
Wed Mar 17, 2021 6:05 am
Same, I have both.
deadchip12
Post by deadchip12 »
Wait, hold up... So you mean this only works when that hard drive contains nothing but that movie's folders?
baker99
Post by baker99 »
Makes me wonder if there's a hacky way of having multiple films by building a structure with each film being a separate chapter (yes it would mess up chapters in each individual movie)
deadchip12 wrote:
Wed Mar 17, 2021 7:26 am
you can have other files/folders in the hdd but only one bluray folder structure in the root will trigger DV.
jedd_ai
Post by jedd_ai »
NiCE77 wrote:
Wed Mar 17, 2021 7:01 am
Same, I have both.
Any difference between Ugoos and Minix in terms of DV format support? Which one would you recommend,?
