mattmarsden
#4696 Post by mattmarsden » Tue Mar 16, 2021 7:57 pm
#4697 Post by RESET_9999 » Tue Mar 16, 2021 8:03 pm
HDR10 is max 4000 nits
https://www.rtings.com/tv/learn/hdr10-vs-dolby-vision
not true. HDR10 is max 10 000nits
spears and munsil:
Maximum Content Light Level : 10000 cd/m2
Maximum Frame-Average Light Level : 1676 cd/m2
Mad max (one of the first HDR movie):
Maximum Content Light Level : 9918 cd/m2
Maximum Frame-Average Light Level : 3241 cd/m2
there are also a lot of movies with maxcll higher than the mastering display luminance. (maxcll is not always accurate though).
there is also Blade runner 2049 that was mastered on a 10k nits monitor but only have a maxcll of 181 nits
https://docs.google.com/spreadsheets/d/ ... =184653968
#4698 Post by RESET_9999 » Tue Mar 16, 2021 9:59 pm
mmm... I just got my Ugoos and very bad news: there's no 23.976 mode, only 24hz.
99% of movies are 23.976, so this device is useless. I hope I can return it...
FYI, playing 23.976 content in 24hz = dropped/repeated frames every 42seconds.
hepe9
#4699 Post by hepe9 » Tue Mar 16, 2021 10:10 pm
Manixx2020beyound wrote:
Tue Mar 16, 2021 3:39 pm
So Chromecast can read fel?
#4700 Post by Manixx2020beyound » Tue Mar 16, 2021 10:23 pm
Trying 1 last time
Set timer came back tv was off lol
Strange thing doe if I force LLDV from the device it plays the whole movie but NO fel
Trying when it triggers naturally is the issuse .
But I’ll keep trying seeing that the ugoos is no go.
Sonyx700 or streaming platform still the best option for fel movies.
mattmarsden
#4701 Post by mattmarsden » Tue Mar 16, 2021 11:09 pm
Use the Kodi DV build and it will do all framerates correctly.
#4702 Post by RESET_9999 » Tue Mar 16, 2021 11:22 pm
thanks, will try that...
EDIT: yep 23.976 works with kodi .. phew!
bobbymkV
#4703 Post by bobbymkV » Wed Mar 17, 2021 12:06 am
Broooooooooo
Mine just shipped so you had me freaked out lol
#4704 Post by RESET_9999 » Wed Mar 17, 2021 1:01 am
LOL
so far so good.. didn't try on my Atmos capable setup yet but I will test it more tomorrow.
#4705 Post by RESET_9999 » Wed Mar 17, 2021 1:15 am
this is not UGOOS related but I just learned that if you remux DV to bluray folder structure with tsMuxer and you put the files in the root of an USB drive, the Sony x700 is able to play it in dolby vision with chapters, working FF RW for long movies and no more green screen bug when you stop playback.
mulucy
#4706 Post by mulucy » Wed Mar 17, 2021 1:29 am
Wow, that's fantastic! I need to try that too! BTW, I see you got a Ugoos delivered. Are you able to confirm that it in fact supports the FEL titles and plays it correctly?
deadchip12
#4707 Post by deadchip12 » Wed Mar 17, 2021 2:15 am
That's awesome!
#4708 Post by RESET_9999 » Wed Mar 17, 2021 2:21 am
It's definitely processing the FEL as @mattmarsden confirmed. The Power Rangers ending credits is bright white and because I fast-forwarded, it kind of froze and it caused ghosting. I clearly saw the grey HDR10 BL and the EL on top of it.
At first, playback was not very stable but now Power rangers is playing for an hour and everything looks stable.
I'll have a deeper look at the colors on my OLED tomorrow. it looks very promising.
#4709 Post by RESET_9999 » Wed Mar 17, 2021 2:32 am
What if the movie is already in bdmv structure, then which files do we put in tsmuxer?
you drag and drop the correct mpls file into tsmuxer and create a new bluray structure.
deadchip12
#4710 Post by deadchip12 » Wed Mar 17, 2021 2:33 am
Awesome. Thanks.
