LG BU40N -keeps spinning even after reading / ripping operation has completed. How to stop this (aside from ejecting)??
njweb
Post by njweb » Tue Mar 16, 2021 5:01 pm
I did a search for 'BU40N' and 'spinning' but could not find any hits.
When I perform a disc ripping operation (e.g. with one of my UHD original discs), even after the operation has completed (100%), the drive stays in spin up mode / disc keeps spinning.
Unless I open the tray, the spinning continues indefinitely which could wear down the motor over a period of time.
Aside from manually ejecting the drive tray every time when the disc reading operation has completed, which is not a convenient solution since sometimes I leave for a while and come back an hour or more later, is there any systematic way to stop this continual spinning / spin up from happening?
Re: LG BU40N -keeps spinning even after reading / ripping operation has completed. How to stop this (aside from ejecting
Post by Woodstock » Tue Mar 16, 2021 6:08 pm
That may be MakeMKV trying to get around the sleep bug - a lot of UHD drives won't work after they stop spinning.
You can test this by exiting MakeMKV. If the drive doesn't stop, something else is keeping it moving.
njweb
Post by njweb » Tue Mar 16, 2021 6:45 pm
Thanks.
Sorry, to clarify, I posted here since I bought it based on recommendations here for use with MakeMKV, which I have used. This was happening with CloneBD, but I think it happens with MakeMKV too (but have not use MakeMKV for over a month). Pretty sure that even after exiting the program it continues, until I eject the tray...
Post by Billycar11 » Tue Mar 16, 2021 11:13 pm
The default behavior of makemkv is after rip is done drive spins down you have something else causing that
Every BU40N I ever tested spins down after rip
