I'd like to find out how I can change the following in the default profile?
Basically I want video to show lang as undetermined instead of eng and also want all mono and stereo tracks as flac.
Could anyone help
Changing default profile?
Re: Changing default profile?
Have you tried selecting the FLAC profile?
Editing the XML files is best done with an XML-aware text editor, so you avoid unbalanced tags, then save the result under a different name in your MakeMKV data directory.
