Basically wondering what people's preferred audio selection is?
I'm aiming more for compatibility so maybe I should stick to just the dts core or the ac3 compatibility track from the atmos/truehd track. Also what if there's pcm audio, would aac be sufficient or would flac be the way to go from your personal experience.
Regards
Ferrett1983
What's your preferred audio selection?
Re: What's your preferred audio selection?
Everything.
I then sort it out after ripping, using handbrake. I have handbrake generate files with AC3, AAC, and often "pass through" the higher-spec audio for when I decide to put a better theater amp in place.
