What's your preferred audio selection?
Ferrett1983
Post by Ferrett1983 » Tue Mar 16, 2021 8:31 pm
Basically wondering what people's preferred audio selection is?
I'm aiming more for compatibility so maybe I should stick to just the dts core or the ac3 compatibility track from the atmos/truehd track. Also what if there's pcm audio, would aac be sufficient or would flac be the way to go from your personal experience.
Regards
Ferrett1983
Re: What's your preferred audio selection?
Post by Woodstock » Tue Mar 16, 2021 8:51 pm
Everything.
I then sort it out after ripping, using handbrake. I have handbrake generate files with AC3, AAC, and often "pass through" the higher-spec audio for when I decide to put a better theater amp in place.
