#4651 Post by RESET_9999 » Sun Mar 14, 2021 2:26 pm
deadchip12 wrote: Sun Mar 14, 2021 11:26 am I'm trying to add this file into tsmuxer (to mux it to .ts) but nothing shows up. Both the input files box and tracks box are blank. It's the first time this happens with a file. What's wrong with the file?
yep, some mp4 won't show up in tsMuxer. I think it's because of the way they are muxed, the same happens when I mux DV with mp4box.
the solution is to demux the mp4 and then you can build a new TS file.
https://github.com/DolbyLaboratories/dlb_mp4demux
X:\mp4demuxer_32bits.exe --input-file X:\DV.mp4
this is good for the video/audio stream but the subtitles will be extracted as .dat file... I use mymp4boxGUI to extract the subtitles to SRT.
https://www.videohelp.com/software/My-MP4Box-GUI
I also noticed that the x700 doesn't like the DV files that were encoded with cropped resolution (no black bars). The black bars are grey on the x700....
All the AppleTV+ web-dl have cropped resolution. The Shield has no issues with those files, I wonder if it's the same behavior on the oppo.
bronan
#4652 Post by bronan » Sun Mar 14, 2021 4:35 pm
DaMacFunkin wrote: Sun Mar 14, 2021 10:48 am
bronan wrote: Sat Mar 13, 2021 10:52 pm I have an Oppo-203 I've been using for UHD playback as well as rips from a network share. I just learned the Dolbyvision playback on it is less than stellar, it's much dimmer than playing through the TVs video app. I want to replace it, but what's the best UHD player out now for handling DolbyVision? Being able to play DV rips on a network share would be a huge bonus!
As glc says, Oppo is generally accepted as the best you can get for Dolby Rips.
Factory reset your Oppo and don’t change any settings except for source direct and TV-led processing, leave everything else as auto (Confirmed by Vincent). People have ate fancy to change the bit and colour depth settings, don’t.
If your TV doesn’t support TV led processing, then you are stuck with that picture and no other Dolby streamer will do it better as they all have the same LLDV sdk.
Also we have had this on this forum before where someone has stated that the internal player is brighter and it turned out the files he was comparing where ripped to different containers using different methods and the settings where different for each input, just because something is bright, doesn’t make it right.
I have a LG c9 and the Chinoppo, dual stream (not dual layer) mp4 looks the same via internal Plex as it does on Chinoppo via TV led processing.
Thanks for the help! I am comparing m2ts, ts and mp4 containers via the built-in LG CX video player and Plex versus the Oppo. I had tried changing between TV and Player led but strangely both looked the same - dim and flat. I did a factory reset on the Oppo and now the TV and Player led settings look different. The Player led looks similar to before, while the TV led is actually overly bright now using the same video settings. So that's a bit weird, but after notching down Brightness its close enough that I'm not going to lose any sleep over it.
#4653 Post by Manixx2020beyound » Sun Mar 14, 2021 5:50 pm
Ending credits Power rangers
Hdr10 version is faded
LLDV dune version not playing Fel from iso.
Sony x700 LLDV using the Fel.
As we can see LLDV on dune looks worse than the real hdr10 comparison when not using the fel.
And when internal LLDV processing is done right fel it is clearly diff from hdr10.
Actually during playback on the dune just the ending credit there were green white red blue flashing in the background as it seems to disregard the fel on the fly.
If anyone can show a comparison with the real hdr10 credits looking like the x700lldv I’ll rest my case that LLDV is NOT worse than hdr10.lol
Fel
Last edited by Manixx2020beyound on Sun Mar 14, 2021 7:16 pm, edited 5 times in total.
chros
#4654 Post by chros » Sun Mar 14, 2021 6:02 pm
RESET_9999 wrote: Sun Mar 14, 2021 2:26 pm I also noticed that the x700 doesn't like the DV files that were encoded with cropped resolution (no black bars). The black bars are grey on the x700....
Yes, same on Oppo, firestick4k with patched kodi19 is fine.
Big-rome
#4655 Post by Big-rome » Sun Mar 14, 2021 9:21 pm
I just flashed the minix u22 with the ugoos am6 0.4 firmware and all my mkv rips trigger dolby vision. I'm using the fandangos build. In the settings you can choose between player led and tv led, I did tv led. Dolby atoms pass thru working also. Only problem I have is when stopping the movie, it does not go back to the kodi menu.
DaMacFunkin
#4656 Post by DaMacFunkin » Mon Mar 15, 2021 6:58 am
Big-rome wrote: Sun Mar 14, 2021 9:21 pm I just flashed the minix u22 with the ugoos am6 0.4 firmware and all my mkv rips trigger dolby vision. I'm using the fandangos build. In the settings you can choose between player led and tv led, I did tv led. Dolby atoms pass thru working also. Only problem I have is when stopping the movie, it does not go back to the kodi menu.
Hi, are you convinced it is correctly processing the FEL stream from the MKV?
Is playback smooth or is their micro stutters and / or Pauses?
Thank you.
Fuso90
#4657 Post by Fuso90 » Mon Mar 15, 2021 7:25 am
Is it possible to make a MP4 mux of a MKV DoVi encoded file?
I tried with this movie. This is the original file's info:
File size                                : 40.6 GiB
Duration                                 : 3 h 48 min
Overall bit rate                         : 25.5 Mb/s
Movie name                               : The Lord of the Rings: The Fellowship of the Ring 2001 Extended UHD BluRay 2160p TrueHD 7.1 DoVi x265-DON
Encoded date                             : UTC 2021-01-04 09:55:35
Writing application                      : mkvmerge v51.0.0 ('I Wish') 64-bit
Writing library                          : libebml v1.4.0 + libmatroska v1.6.2
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 21.2 Mb/s
Height                                   : 1 608 pixels
Display aspect ratio                     : 2.40:1
Bits/(Pixel*Frame)                       : 0.143
Stream size                              : 33.8 GiB (83%)
Title                                    : The Lord of the Rings: The Fellowship of the Ring 2001 Extended UHD BluRay 2160p TrueHD 7.1 DoVi x265-DON
Writing library                          : x265 3.4+35-772bb4c84:[Windows][MSVC 1928][64 bit] 10bit
Encoding settings                        : cpuid=1111039 / frame-threads=4 / numa-pools=24 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1608 / interlace=0 / total-frames=328264 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=5 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=8 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=40 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=4 / tu-intra-depth=4 / limit-tu=4 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=4 / limit-refs=1 / limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=2.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.5 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / min-vbv-fullness=50.0 / max-vbv-fullness=80.0 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=0.70 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50) / cll=602,184 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass
Maximum Content Light Level              : 602 cd/m2
Maximum Frame-Average Light Level        : 184 cd/m2
I split a small file with MKVToolNix GUI version: 55.0.0 and this is the info:
File size                                : 202 MiB
Duration                                 : 52 s 249 ms
Overall bit rate                         : 32.4 Mb/s
Encoded date                             : UTC 2021-03-14 10:43:27
Writing application                      : mkvmerge v55.0.0 ('Waiting For Space') 64-bit
Writing library                          : libebml v1.4.2 + libmatroska v1.6.4
Video
Duration                                 : 52 s 219 ms
Bit rate                                 : 32.0 Mb/s
Bits/(Pixel*Frame)                       : 0.216
Stream size                              : 199 MiB (99%)
After that I extract the video and audio with eac3toGUI 1.3.0 and mux them with mp4muxer:
mp4muxer.exe --dv-profile 5 --input-file 1.hevc --input-file 3.ac3 --media-lang eng --output-file movie.mp4
... and this is the final file's info:
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/dby1/isom)
File size                                : 202 MiB
Duration                                 : 52 s 257 ms
Encoded date                             : UTC 2021-03-14 15:20:23
Tagged date                              : UTC 2021-03-14 15:20:23
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Duration                                 : 52 s 218 ms
I tried with profile 4, 5, 7 but it's all the same when I try to play it directly on LG B8. It takes longer to load the file, it shows Dolby Vision logo but there's no picture at all, only sound. Also tried muxing directly with tsMuxerGUI 2.6.16-dev but the result is the same. And with profile 8 the file plays in regular HDR.
mattmarsden
#4658 Post by mattmarsden » Mon Mar 15, 2021 9:08 am
Can you point me in the direction of the custom AM6 firmware for the Minix. Thanks
NiCE77
#4659 Post by NiCE77 » Mon Mar 15, 2021 10:54 am
mattmarsden wrote: Mon Mar 15, 2021 9:08 am
https://4pda.ru/forum/index.php?showtop ... y103863672
Big-rome
#4660 Post by Big-rome » Mon Mar 15, 2021 11:02 am
DaMacFunkin wrote: Mon Mar 15, 2021 6:58 am
Thank you.
Yes, I have a x1100es to compare it to. Even aquaman looks exactly like the Blu-ray.
lexyz
#4661 Post by lexyz » Mon Mar 15, 2021 11:16 am
Aquaman is MEL
hepe9 wrote: Thu Mar 11, 2021 8:52 pm I have the same TV, do you prefer DV to HDR even if it is less bright?
Difference is too subtle to worry about
Big-rome
#4662 Post by Big-rome » Mon Mar 15, 2021 11:27 am
I thought I read that aquaman was problematic. I tried aquaman, Gemini man, ready player one and Alita battle angel. All look exactly like the Blu-ray version.
DaMacFunkin
#4663 Post by DaMacFunkin » Mon Mar 15, 2021 11:45 am
Big-rome wrote: Mon Mar 15, 2021 11:27 am I thought I read that aquaman was problematic. I tried aquaman, Gemini man, ready player one and Alita battle angel. All look exactly like the Blu-ray version.
Cool, may be tempted, thank you.
Big-rome
#4664 Post by Big-rome » Mon Mar 15, 2021 11:59 am
Just tried black panther and bumblebee. Both movies show correctly. I will try a few more later.
#4665 Post by RESET_9999 » Mon Mar 15, 2021 2:08 pm
these are all MEL movies.
