US Retail
Title information
Source file name: 00900.mpls
Duration: 1:42:35
Chapters count: 16
Segment count: 15
Segment map: 514,510,503,509,504,505,507,501,513,512,502,511,515,506,508
File name: Fatale_t138.mkv
Fatale
swervarelli
Re: Fatale
Would this happen to be the redbox version?
hytech1956
Re: Fatale
Any info for the Redbox version?
PrideOfPR7
Re: Fatale
Confirmed that this is the same on RB. ProcMon verified:hvnphoto wrote: Mon Feb 22, 2021 2:42 am US Retail
Title information
Duration: 1:42:35
Chapters count: 16
Segment count: 15
G:\BDMV\STREAM\00514.m2ts SUCCESS
G:\BDMV\STREAM\00510.m2ts SUCCESS
G:\BDMV\STREAM\00503.m2ts SUCCESS
G:\BDMV\STREAM\00509.m2ts SUCCESS
G:\BDMV\STREAM\00504.m2ts SUCCESS
G:\BDMV\STREAM\00505.m2ts SUCCESS
G:\BDMV\STREAM\00507.m2ts SUCCESS
G:\BDMV\STREAM\00501.m2ts SUCCESS
G:\BDMV\STREAM\00513.m2ts SUCCESS
G:\BDMV\STREAM\00512.m2ts SUCCESS
G:\BDMV\STREAM\00502.m2ts SUCCESS
G:\BDMV\STREAM\00511.m2ts SUCCESS
G:\BDMV\STREAM\00515.m2ts SUCCESS
G:\BDMV\STREAM\00506.m2ts SUCCESS
G:\BDMV\STREAM\00508.m2ts SUCCESS
Balderdash!
Re: Fatale
The RB version does not contain the file "Fatale_t138.mkv".
Re: Fatale
Confirmed 00900.mpls for RB version picked up yesterday.
Re: Fatale
File name depends on your minimum title length - titles smaller than that aren't counted.
Balderdash!
Re: Fatale
Hey, thanks for the clarification.
bonerb1981
Re: Fatale
I have 4 different tracks on the DVD RB version of this movie. how do you figure out which it is?
Re: Fatale
Second 00900.mpls Fatale_t187.mkv
Title information
Duration: 1:42:35
Chapters count: 16
Segment count: 15
File name: Fatale_t187.mkv for my version of RB
Title information
Duration: 1:42:35
Chapters count: 16
Segment count: 15
Re: Fatale
Just to clarify, the "t" "title" number in the filename is an arbitrary number that MakeMKV assigns based on the order that it loads the content of the disc, which can be affected by factors such as minimum title length as mentioned above.
What you should look at when finding, sharing, or confirming the correct file is what MakeMKV labels as the source file name, generally an mpls playlist number, and commonly referred to as just a playlist:
You can also add this "source" number, which will either be an mpls playlist or an m2ts file, to the filenames that MakeMKV creates by going into your preferences and changing the "Default Output File Name Template" to include "{_s:SN}"
Using: ASUS BW-16D1HT 3.00
