Techpulse120 BU40N 1.04
mark96
Post by mark96 »
Hey guys,
first of, wow and thanks for this amazing forum. Just came across it, a week after I bought my blu-ray burner.
My situation looks as follows:
I got a Techpulse120 with this informations
OS device name: E:
Product: BD-RE BU40N
Revision: 1.04
Serial number: -
Firmware date: 2120-05-06 11:42
Highest AACS version: 61
Harware support: Yes
Firmware support: No
Firmware version: 1.04
Full HD blu-rays are no problem to rip. Tho I am not able to watch them or even rip 4K blu-rays (the former is not my number one priority).
full-error-log.txt
MakeMKV v1.16.1 win(x64-release) started
Backing up disc into folder "D:/Video/backup/THE_MATRIX"
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Downloading latest HK to C:\Users\USERNAME/.MakeMKV ...
Saved AACS dump file as C:\Users\USERNAME/.MakeMKV/MKB20_v61_THE_MATRIX_2077.tgz
Backup failed
I tried to rip the 4K blu-ray on Linux and Windows on two different machines, with the same errors. (Got only this one, so no other 4K disc for comparison)
After my assumption, the firmware of the drive is the problem. (No signs of inssuficent power for the drive, blu-ray "The Matrix" was released 2 years ago and other users reported successful rips, I don't try to rip from an ISO/backup - https://www.makemkv.com/faq/item/11)
Also: viewtopic.php?f=16&t=19634
All of these drives will need to be flashed to unlock UHD Reading/Ripping
LG BU40N, UHD Official Internal Slim Sata 9.5mm
Here Billycar11 suggests
BU40N on any Firmware directly to > BU40N 1.03MK
Is this also true for the above mentioned 1.04? I didn't found a 'BU40N 1.03MK'-firmware
With the SDFtool I already tried to dump the current firmware of my drive with 'READ Firmware' but only got the user data 'dump_user_HL-DT-ST_BD-RE_BU40N_1.04_212005061142_[SERIALNUMBER].tar'
Last but not least, I'm a bit confused about the encrypted firmwares here:
Newer OEM Firmwares and encrypted:
New Encrypted firmware
List of Know Encrypted firmware (so far, any firmware with date in 2020 is encrypted)
HL-DT-ST-BD-RE_BU40N-1.04-N000500-212005061142.bin
LG 1.04+ / BU40N 1.03 / Asus 3.10+ and similar
I guess this affects my device but couldn't find out where to see the exact installed firmware of my drive (which is why I tried to dump it with the SDFtool, like mentioned above). I only can asume it's something like HL-DT-ST-BD-RE_BU40N-XXXXXXX-212005061142
...and there is no MK version of the same firmware/drive model or higher number...
But there is the, again, above mentioned 'HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin', so I can use this?
My questions would be, did I miss anything? And if not, can I just flash it with "mk-firmware-pack-20200720 \ MK \ HL-DT-ST\BU40N-N-Main \ HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin" and the SDFtool? Is the 'DE'-firmware (DE_LG_BU40N_1.00.bin) any use to me?
I hope my thoughts are not too confuesd.
In advance I would like to thank you for every bit of advice.
Re: Techpulse120 BU40N 1.04
Feel free to email me for an automated flasher does it all for you windows only
brimaporima
Post by brimaporima »
i have exactly the same drive, with the same firmware (with that weird firmware date) and run into exactly the same problem. Only difference: I'm using MacOS, and my makemkv version is 1.16.3
mark96, did you find a solution to your problem?
Regards,
Brima
ariela
Post by ariela »
Hi All,
I've the same device, with this drive information:
Revision: FR07
Serial number: 807HS013285
Firmware date: 2118-01-22 15:36
Bus encryption flags: 1F
Highest AACS version: 72
Firmware version: 0.FR07J
Unrestricted read speed: Possible (with patched firmw
Any update how to fix it? I've the same issue here. Not able to see/rip 4K discs
Andrea
ariela wrote: Mon Nov 08, 2021 11:09 am Hi All,
Revision: FR07
Andrea
Read the guide linked below or get a self flash kit
