Hi guys,
after successefully creating mkvs with makemkv from UHD I realized interruptions playing them with VLC (version 3.0.2) on my Intel MacBook Pro (2019/Big Sur). Increasing local caching up to 10.000 ms did not help. My VLC can manage non-UHD mkvs without any trouble.
Quicktime does not open UHD mkvs and complains about unknown file format. But I don't like Quicktime anyway.
Do you have any recomandations for a good player app on macos, which deals with UHD mkvs? I'm fine to pay for it, if it works.
Regards, Sisyphos
Good MacOS App for UHD mkvs?
Re: Good MacOS App for UHD mkvs?
Dvdfab has a player for Mac OS, cost varies on how long you want the license to last. I use the Windows version though. It has a trial period.
I use MPV (https://mpv.io) on my Mac all the time. I installed it with Homebrew (https://brew.sh). I've heard about IINA (https://iina.io) but I haven't tried it.
IINA works well for me.
Infuse Pro is on my ATV. I back up my discs into BDMV folders and let infuse stream them off Windows 10 Pro box where the rips live.
I believe Infuse does MKV as well.
Sorry I spaced out on the MacOS requirement.
I don’t actually know of one. Love to see the DVDfab player but it seems you get to the $265 price tag really quick lol. Not sure I can drop that on DVDfab right now
Low Winter Sun
I"ve never had any pausing issues with UHD disks and VLC on any of my macs. Are you playing them across a network, or are they stored on the mac that you are playing them on?
VLC works just fine for me. Also of note, Infuse is launching a macOS app also!
infuse pro beta working fine on my M1 Mac Mini.
VLC too and plex, but infuse is my go to even in beta.
