The Giver - multiple playlists
matt198t
Post by matt198t »
Any help with the UK Blu-ray?
preserve
Re: The Giver - multiple playlists
Post by preserve »
Did you ever verify the UK release of The Giver?
Disc Information
Label: THE_GIVER
Timestamp: 2014-12-01 13:12:09
Data capacity: 45.88 Gb
Disc type: BD-ROM
Number of layers: 2
Protection: AACS v50
In the forum of a certain colored animal, they recommend playlist 506. I haven't had the chance to watch it yet, but will edit this once confirmed.
Title information
Name: The Giver (English)
Source file name: 00506.mpls
Duration: 1:37:19
Chapters count: 12
Segment count: 10
Segment map: 781,110,103,112,105,113,104,102,106,111
File name: The Giver_t59_s00506.mkv
On a somewhat related note, if anyone has the US release, I'd be interested to know what the bitrate there is and what the encode style is. They've gone for a very constant approach on this encode, with an average AVC video bitrate of 29.726 mbps.
AV Sync log with MakeMKV 1.15.4:
AV synchronization issues were found in file 'The Giver_t59_s00506.mkv' (title #60)
AV sync issue in stream 1 at 0:06:00.526 with duration of 6.5ms : encountered overlapping frame, audio skew is +6.5ms
AV sync issue in stream 1 at 0:06:31.265 with duration of 2.291ms : encountered overlapping frame, audio skew is +8.791ms
AV sync issue in stream 1 at 0:07:15.643 with duration of 6.333ms : encountered overlapping frame, audio skew is +15.125ms
AV sync issue in stream 1 at 0:07:15.658 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +4.458ms
AV sync issue in stream 1 at 0:13:00.905 with duration of 7.75ms : encountered overlapping frame, audio skew is +12.208ms
AV sync issue in stream 1 at 0:13:00.917 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +1.541ms
AV sync issue in stream 1 at 0:13:24.345 with duration of 5.25ms : encountered overlapping frame, audio skew is +6.791ms
AV sync issue in stream 1 at 0:15:17.416 with duration of 6.041ms : encountered overlapping frame, audio skew is +12.833ms
AV sync issue in stream 1 at 0:15:17.429 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.166ms
AV sync issue in stream 1 at 0:15:46.111 with duration of 8.666ms : encountered overlapping frame, audio skew is +10.833ms
AV sync issue in stream 1 at 0:15:46.122 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.166ms
AV sync issue in stream 1 at 0:16:34.118 with duration of 4.375ms : encountered overlapping frame, audio skew is +4.541ms
AV sync issue in stream 1 at 0:17:16.660 with duration of 6.833ms : encountered overlapping frame, audio skew is +11.375ms
AV sync issue in stream 1 at 0:17:16.672 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.708ms
Forced subtitles track #3 turned out to be empty and was removed from output file
1 titles saved
Using: ASUS BW-16D1HT 3.00
dkb441
Post by dkb441 »
I have the european zone B version, with a product code EBR 5252 written on cover and disk.
This one works with using the file The Giver_t58.mkv. That file is 22.9GB and my disc has id: 962F8BA0A5016FC2F8D470EADA74178717CF85E5
dkb441 wrote: Fri Jul 11, 2025 8:22 pm I have the european zone B version, with a product code EBR 5252 written on cover and disk.
The segment map and/or the source file name from the right side of the MakeMKV window are the things that uniquely identify a title on a disc. The file that ends up being named The Giver_t58.mkv on your system might not be the same file on my system.
