LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
Whoops
Post by Whoops » Tue Jul 14, 2020 4:12 am
I am using 1.15.1 and trying to rip a DVD and the rip fails at the end of the process every time. I am able to use DVD Decrypter to make an ISO that tests as valid upon completion and when I mount the ISO I am able to watch the title from start to finish with no audio sync or visual errors that I can see. The source DVD also plays just fine and has a flawless surface with no oils, dust or scratches. Ripping to a different directory or changing the names of the resulting files has no impact. Turning on debug shows the following.
Downloading latest SDF to C:/Users/joeuser/.MakeMKV ...
Automatic SDF downloading is disabled or failed.
DEBUG: Code 121 at yv"y}$N<9>6(HCzT:29407523
Using LibreDrive mode (v06.2 id=E064BA3E3F81)
Title #1 was added (17 cell(s), 1:47:30)
Title #3 was added (1 cell(s), 0:02:24)
Title #4 was added (1 cell(s), 0:02:12)
Title #5 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory D:/
Failed to save title 0 to file D://DVD_Title.mkv
0 titles saved, 1 failed
When I try to enable *TESTDUMP*, it creates a 298kb TGZ file and then MakeMKV displays an error message that states "Fatal error occured, program will now exit." with the option to hit OK. Once you hit OK the program crashes to the desktop.
EDIT: I also tried ripping from the mounted ISO and the same error happens.
m20120
Re: LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
Post by m20120 » Wed Jul 22, 2020 12:20 pm
I encountered this same error trying to rip another DVD. I searched and found a reference to this error in a post from about 2 years ago. It was suggested rolling back to version 1.12.2 may fix the issue. I am happy to report that this worked and I was able to rip this disc.
This was with version 1.15.1. I have not tried the update (1.15.2) that was just released. I will try that to see if it still has the issue if I get a chance. Otherwise you might have to try the old version.
Edit: I just tried 1.15.2 on my problem DVD, and the error still occurs:
MakeMKV v1.15.2 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\m20120/MakeMKV_log.txt
Using LibreDrive mode (v06.2 id=BF04C03F631B)
Title #1 was added (25 cell(s), 1:57:29)
Saving 1 titles into directory E:/Video/The Midnight Special
DEBUG: Code 0 at b.%#`-lFboE?ql{%Y:213130237
Failed to save title 0 to file E:/Video/The Midnight Special/title_t00.mkv
So I guess I have to keep the 1.12.2 version around for a while.
S.p.e.c.t.r.e.
Post by S.p.e.c.t.r.e. » Wed Dec 09, 2020 6:33 pm
I'm using v1.15.3 and this version is also affected.
MakeMKV v1.15.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\blah/MakeMKV_log.txt
DEBUG: Code 233 at 2uK69KmHeALtbdo64Own9nNl:0
Saving 1 titles into directory G:
Failed to save title 0 to file G:/title_ID-01.mkv
Here's the makemkv_log.txt info:
Debug log started at Wed Dec 09 18:12:08 2020 , written by MakeMKV v1.15.3 win(x64-release)
Using 1048320KB for read cache.
001005:0000 MakeMKV v1.15.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\blah/MakeMKV_log.txt
No  SDF v07d: HL-DT-ST_BD-RE__WH16NS40_1.04_211901041348_KLHK36D2306
DEBUG: Code 0 at P%;<d:z,OXCeq6Ymv:213132284
DEBUG: Code 0 at 6U|+czx4G wB(hAY:121268604
DEBUG: Code 3 at !-!"R$A%ucExUN:=,c&[KL| :29395310
SDF id v07d: HL-DT-ST_BD-RE__WH16NS40_1.04_211901041348_KLHK36D2306
003028:0000 Title #1 was added (17 cell(s), 1:47:30)
003028:0000 Title #3 was added (1 cell(s), 0:02:24)
003028:0000 Title #4 was added (1 cell(s), 0:02:12)
003025:0000 Title #5 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at 2uK69KmHeALtbdo64Own9nNl:0
005014:0000 Saving 1 titles into directory file://G:
CCX001: Launching C:\Program Files (x86)\MakeMKV\mmccextr64.exe
CCX001: CCExtractor 0.85, Carlos Fernandez Sanz, Volker Quetschke.
CCX001: Teletext portions taken from Petr Kutalek's telxcc
CCX001: This is a reduced-functionality version optimised for DVD closed captions transcoding.
CCX001: --------------------------------------------------------------------------
CCX001: Reading from standard input
CCX001: Analyzing data in CCExtractor's binary format
CCX001: Sending captions to stdout.
001002:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
---- Failed G:/title_ID-01.mkv
ch_0        6837578748000 0
ch_1        6838119288000 0
ch_2        6838659828000 0
ch_3        6839200368000 0
ch_4        6839740908000 0
ch_5        6840281448000 0
ch_6        6840821988000 0
ch_7        6841362528000 1
mt=00000267DE9198B0 n=3
s=0 n=13 o=4051906560
    0  52352 000011  6840821988000       36036000 1EE4B12D 000001B32D01E03415FA238110111112121213131313141414141415151515151516161616161616171717171717171718181819181818191A1A1A1A191B1B1B1B1B1C1C1C1C1E1E1E1F1F21000001B51482000100000000000001B88ADC6B0000000100008FFFF8000001B58FFFF79C00000000000001B2050B0ADC6CFF050C
    0  26944 000018  6840731898000       36036000 C0C3AB70 00000100001FFFFBB8000000000001B58555571C00000000000001B2050B0ADC6B7F050C8080B8E1000000000000000000000000000000000000000000000000000001017A57299C8287A0D4F08A6895152A29941A1A05109F8B0C26252BE5715C05780D1B64A2681F2884900951F7574994D6C3CE4944D66E8286E3D1CCFED0
    0  11328 000018  6840767934000       54054000 736182AF 00000100005FFFFBB8000000000001B58555571F80000000000001B2050B0ADC6BFF050C8080C9B9000000000000000000000000000000000000000000000000000001017A57299C828862834C7A688D111A39809920274312F80580641180196039602429279DE0C2694949412CC410F154D6C1CC0600272117F39C6E08FB88
    0  31680 000010  6840948114000       54054000 F9713430 000001000157FFFB80000000000001B5855FF71F80000000000001B2050B0ADC6E7F050C8080D987000000000000000000000000000000000000000000000000000001017A08DF87DA3468C30D1A3468D1861A3468D1A30C3468D1A3461868D1A3468C30D1A3468D1861B897A4C028422600EC0A9403A02A4D19D5F86145934A
    0  19264 000018  6840858024000       54054000 2732D069 0000010000DFFFFBB8000000000001B58555579F80000000000001B2050B0ADC6D7F050C8080C791000000000000000000000000000000000000000000000000000001017A57299C83874A837663E9C628B803B006000EC032E801D009FE01D867045FFB01D041605B823001A455EF3A1084129034057905216838C331A773FC
    0  17408 000018  6840912078000       36036000 2BFE9A3D 00000100011FFFFBB8000000000001B58555571C00000000000001B2050B0ADC6DFF050C8080CAE5000000000000000000000000000000000000000000000000000001017A57299C83874E83619BF19F8704E1273B391575A20D0E6009800C4042008801D003FC01A0680601A7A1C04E42262381529243E349AF938343508C48
    0  37312 000010  6841092258000       36036000 A438DAF0 000001000217FFFB80000000000001B5855FF71C00000000000001B2050B0ADC817F050C8080C7A7000000000000000000000000000000000000000000000000000001017A08BF87DA3468C30D1A3468D1861A3468D1A30C3468D1A3461868D1A3468C30D1A3468D1861A3C6F53FF004A00C001BFB117A007DF7F80077089EF0
    0  14976 000018  6841002168000       36036000 C62BE1AB 00000100019FFFFBB8000000000001B58555579C00000000000001B2050B0ADC807F050C8080BD88000000000000000000000000000000000000000000000000000001017A57299C83864692200E4019006A50034005E019806001916E67C03B02803B4A0A6EBC78E4759D49E83B7E256B1E463CDAD56EB73002CE00DC340189
    0  13312 000018  6841038204000       54054000 A6B5B0D9 0000010001DFFFFBB8000000000001B58555579F80000000000001B2050B0ADC80FF050C8080C5E1000000000000000000000000000000000000000000000000000001017A57299C8246B2D8F41000B4034002B006E009C06202104101600C0300A014210690C9BCA00D00408042FF50D2F842119FFEA31C0C230DFFD6A93459
    0  32640 000010  6841218384000       54054000 E055B0BF 0000010002D7FFFB80000000000001B5855FF79F80000000000001B2050B0ADC837F050C8080C4EA000000000000000000000000000000000000000000000000000001017A08BF87DA3468C30D1A3468D1861A3468D1A30C3468D1A3461868D1A3468C30D1A3468D1861A3468D1A30C34C074F3737142796A37E1F68C6306186
    0  14016 000018  6841128294000       54054000 A29AD4A6 00000100025FFFFBB8000000000001B58555571F80000000000001B2050B0ADC81FF050C8080B7F6000000000000000000000000000000000000000000000000000001017A57299C824633D9F402E007401800C00A80EC8603B2186908AC7961A430C2600A0A4F080F27D69F980E806042288603B0C26134B4635280C497B27E
    0  11649 000018  6841182348000       36036000 0E1C3583 00000100029FFFFBB8000000000001B58555579C00000000000001B2050B0ADC82FF050C8080C4FA000000000000000000000000000000000000000000000000000001017A57299C819BF0FB160D1861A70133CDA415B539CD08DA423539CD08DA42353957328ADA4235719E76D5B2A95239CE768A2B6FE8DF87DA37D501000D
    0  49408 000013  6841362528000       36036000 85D099A2 000001B32D01E03415FA238110111112121213131313141414141415151515151516161616161616171717171717171718181819181818191A1A1A1A191B1B1B1B1B1C1C1C1C1E1E1E1F1F21000001B51482000100000000000001B88ADC838000000100008FFFF8000001B58FFFF79C00000000000001B2050B0ADC857F050C
s=1 n=1 o=4051984384
    1    768 000001  6840840960000       34560000 6569C465 0B77C9DA1440437FF306F362DD05090807A0E06080B05612BB4AFAB5372FD53A54A9F2A850A93EA6F9ED3735DCDAAD615115645F5284F9DA49D56112890839C86B59638904D4C373AADD6ACAA9474D4973F7C99CD75646849629441B463CEB8BA6EC24D3026AD0DD3EA69A9A59B5E956AEA9CDBA54A13FF2DE7E4C99200A1D10
s=2 n=1 o=0
    2     33 000011  6658479720000   263799720000 EFFF72AC 202020202020202020202020474F204F4E2E20202020202020202020202020200A
mt=00000267DDEC5300 n=3
s=0 n=1 o=4051906560
    0   9600 004018  6841272438000       36036000 6CC300EB 00000100001FFFFBB8000000000001B58555571C00000000000001B2050B0ADC83FF050C8080B7D4000000000000000000000000000000000000000000000000000001017A57299C3299D95D5C387054F96D55CE019ECFA4232FAA8DF87DA3462C30D183462C630C346568CD1A461868CAD18C691861AA6794CF1BF0FB46662C
s=1 n=42 o=4051984384
    1    768 006001  6840875520000       34560000 5A01474A 0B77D2AE1440437FF306F362DD09090907A0606060D05606A9AEFA9A5CD0DF3A54FA1267E9893A6B49FA674FD2BE7E969A5854D32984F9DA597CFE9B88F4AD3069C09B8BA3924875595B58E9DA57750D3267AFD0DC4B4A74CB1C5D4CE7034B709EF1267F6277E95D69B70E141AD612D2A50DF3F7B5D4D6F2DE8040812002ED90
    1    768 006001  6840910080000       34560000 EFCF8705 0B7772861440437FF306F362DD09090805A0604080F05612D2A6E61A5AD0E13E7506B58735A20D44E6156AF06BAD8898A5BAEE5DA5A50219C57B24950B886DAF69C0951B90DE70735D5A5B69D0534D3D539AD0DD567EE681901F4380939CE60A5D565682E2AA561A6A875DF52A4F9FBE54F8B677496156B2DE7CC99320068F6C
    1    768 006001  6840944640000       34560000 121CF921 0B7741FE1440437FF306F362DD080A0808A0804080905608BA7E99D2D86E69437D06E397D59FAA74E9F427B5ABBB4AFC8BEACAD2D67CFDDC45A37202484E7A4379C4938DA96DAA7D597B98D112AA854D4D3ACED05B7EF680F661BB5532BEB86F9EF024D2E26AF1D0D74B5E1BA5499D3F6B49F3F74F6B52B2DE804081201B5E16
    1    768 006001  6840979200000       34560000 543DE717 0B775A611440437FF306F362DD03060807A120C080B05645D67CFA1BE7B5DF2A7D0DD39A6E94D7735A9BF490A9BAA54AB3EA509F537CA9E65DA52133DB022BAEAD5DDBCBA977BF4B09FBCE0AA0DD415D73A54F9DA5A6FB818B28F0AEF61BE7E5D4BF26923BF5B21D4E4CEA1A57D4A9BA5CF9DA9AD06DBEF2DE80408120018709
    1    768 006001  6841013760000       34560000 326B89B6 0B77A4601440437FF306F362DD05070805A100A080F05644257EE9CD354A6DAA7CFC8BE8D4E6D27EE6BBDAD5E13E7CF6C3986E92BF4B0DDCC5717513D86E6BC37D49556870AB5B7D5A1577CFDD297F4755452FA952AD4F772FEB53B8E63CE8895F3F7692E3E7D4E73E539E0097B5DD2A86B94C2A6AA6E5B2DE80C1832015DD77
    1    768 006001  6841048320000       34560000 BA488134 0B775BE01440437FF306F362DD06090806A0C06080F056138C5CFDF427CE92D77CFD0D2AD4DD29AD5DF39D6F94C37CFA13F7AF9F91AEAA1044ACFEBCDA54ABAB4AFE955DFB152F4B09F3F7EA93264C9A13E7CFA13F530F77CAADD2B6BA16B86A9ED826A37D38311C7142FA942AD4DDA622AA1A57BBEB52F2DE80408120047C98
    1    768 006001  6841082880000       34560000 C0FC2B33 0B77F8FE1440437FF306F362DD05070605A0E0C0E0F056435C535A943A34DFB976935D2856A966A55A14374A9ED6B0961427D4DD4D7D49DD435D5E1B9CDB15907D61539B5B152AA549D5288A5FA67E821BECD0A9534B5B8731153AA6A6DBE7D6D2EC4CF9FA67E4953A7D4A142AE99F3F4B46E2984FABB9F2DE81C38720176993
    1    768 006001  6841117440000       34560000 0F46A5EE 0B7769CD1440437FF306F362DD05060605A0E0C0C0F856152985AD5427CFD6BEA35DF42850A1A672FDDB87EF9F427C99F437AFA1BA735A10C786AA010ADAE12E7F4D338E1112BEA499FAA74A9F2B7CF9FA97E994C3549777CFAFD87CFA94E875A1677D49F6B534DFA9A5612C27D4DF5253BE156CEF9EC2F2DE80C1832019DE31
    1    768 006001  6841152000000       34560000 3F6226CD 0B77CFA61440437FF306F362DD06090705A0E060A0F85643D1B6FD2D374F9F3F6AFD2C442A9CD7731086822FA13E8695F52A50A1B97EE9DD46B6AE7AA9EE61AE24EA9B9B561EC3A53A956AD5D5AA734ABBE74AD2D2A50F74510B3E8896008A6F9CD9195E943550ABA673514BEAEA9742735E7437CA5F3EF2DE7F4E9D2017D895
    1    768 006001  6841186560000       34560000 F9058700 0B77BF571440437FF306F362DD0A080807A0208080B85614C2554A9A6735E12E7E95FA9ACF9F3F4CA6B42AF09CD774F9F3E5699EBF4CF9E8C3AF01326A54DEAF4CED2BEAF5ABAB42F9F52B095552A54DF3DB0E5FB9ACFB743117A6A69A9B988594BF73AABC28719DB97D5ABC27CFABBE7E961A5AD4A0DBB2DE80408120026BB2
    1    768 006001  6841221120000       34560000 9ADA10FE 0B77FEFA1440437FF306F362DD06060607A0C0C0C0B85614BF74F96D686A694842F9F52AD0DD3A434DCDAB035F3A54F9F2B4B006434B4A105BB565D26A5AA0DC54E9F52A5AAE2A74F75704B5DFA24B5DEBEAEF9FA5B4FB8130E20D7EAB7527D20AD442E6DD77D0A952D3628DB7E9953E7B5DF5774A5F42B2DE80408120176415
    1    768 006001  6841255680000       34560000 D1F138D6 0B7776A51440437FF306F362DD06060804A0E0E081185615297CF9FBDAD0E93E7E99CC286E9F4E6B6E139A699F3F530D2BEA6A92D67EEE0FE18511D367D46143B69D2D2AEF973F84FD329DEF95A7195E0D3ACF7625A54B84B0AC2B7CFABCE5655F3F4B5B7C78689D426B0E9277D3A7A652E9F537692B43F2DE804081200A8699
    1    768 006001  6841290240000       34560000 A1B03E02 0B7742DF1440437FF306F362DD08080806A0808080F0564DD286F6D5774FA93E7CFD125A50AB3E7EF9EC37E5533A56E5F3E7EE5FBA749619E15D012BAA55AE2654EDCD1E76A4961CE69A67D49FA1CE969C2A4FA93E7EF674D0F53FA6A9D528D0DF3F735ADD784C06BE7B5DF474B0E93EACF9F437C99F3EF2DE8040812001AFFA
    1    768 006001  6841324800000       34560000 9107A6C0 0B77C12A1440437FF306F362DD07050605A0A100C0F056092A4AFDF3AA692C39A4F9D567D4A13F23AD33E5499D527D0A9A57E969A9AD5DDA5D850113E73570475689AD5D76D7A74CD5CEB87095A671AEBA9B6B9FA5A56A743629D37C873BDB76DF3F7CF6BD384ED33E7539F3E8699CEB535ABC2A88EBD6F2DE804081200A1518
    1    768 006001  6841359360000       34560000 21F1B51E 0B77F6AC1440437FF306F362DD06050705A0C0E0C0F0561525A6973BE7B5DF427CFD2C2AD0A02485212AA7CA6B584AFA1AA4B0DCBF735E19DD7D0093A99AE42A4E95CEB856D7A74AEA95287097A5A54AB57530DF52AD0E84AAEB5C7AEA9D34D4A7444CD61BE54FD2BEA55EB2A7CFABB9A56DD3EAE961ABF2DE80408120050400
    1    768 006001  6841393920000       34560000 90570173 0B77E9B01440437FF306F362DD08070806A080C0A0D05641584CF6BA674FA13E7D4D2D683C1EC372FABBE7D49F3DAEBDD24AEFA9401AEA4D757B6670CDFAA1AB7649CE6AD1E1A74AF76264B613257549F56A6AA9B97B6F77B62026A34ABD1B100E4F53AAB747B11CBF4B5AD5786F6BBDAEFD329804533EF2DE8040812007F187
    1    768 006001  6841428480000       34560000 4B7DDDA3 0B77D7C51440437FF306F362DD0A070707A040A0A0B0561329CCFAB5785495427CF9F52AEF9EBF74E9F3F495AC2584FD2BE7D5DCD6850E1A6FB7113A19CE30435689CE68706DC47349F5774FC8BA9D4A942A6A6BBDAF0B7731614444335D190B9FA7199E146B049D3E735B7C2A6E92D8495EB574B5A157F2DE804081201E9D66
    1    768 006001  6841463040000       34560000 1389E53C 0B778D1D1440437FF306F362DD08070707A080A0A0B05610C2CCFD32E54E933A849AB5286F95264B5DD3E835DED784FA15276E92D6A6EE10D6BEB113E99B212F7EE90E6D56A427449927054B6BAA73AEB3E86A97BD7D0B8449AB3FAD4DF42550E00D730AE3E550DB3671BF54384FDCEB7D49FA97F49EDBF2DE80408120198F76
    1    768 006001  6841497600000       34560000 FDCEFEE2 0B773A1A1440437FF306F362DD07080804A0A08081105612AA86969BA7CFB33DB6FAB3EA55D5264CF953E9CFC938B096B9674E5FA586AA1A5C84FDD3ED746D442685FB9D56D7A67B9DF3F5642D3F9BB14C34E39F39A4FB77D114C4734B555C10D7BA54F9F3F549A952855B5BE7D4DD3E4E96B53535D6C3F2DE804081201A22D9
    1    768 006001  6841532160000       34560000 C6F9FECF 0B770AF6144043701306F362DD090A0907A0604060B09643BE7EA9F5286A69AB42FD2477D0DEC386776AC574DA6D784ADD92734B75B5709CDBABB1CD41A99F56859D5964B59F429DCDC86FD2D39CF6DDC4AFE6D6AD6158D7CFA8EFAEF9F42A700856A6A96D65D1FCB7A0102048003C3CAE0748EDF5AC5FFD92C78BF7521720F1
    1    768 006001  6841566720000       34560000 8E5FB47E 0B77473E144043701306F362DD07080707A0A080A0D05610BE7EE94C3835DFA57549F428549FAA4CE953E7CFD2D1B0892BE7EE5F3E7D5E0DE1A2B2020A54A42B1C36751BF1D5BF1AA9EDBA6F5FBE7D9ABAA5CE9F66AD0A7730EE3F71BF357855ABC0195B5C354BD0BF735B5AB4CE73BEAB11D2674892AEB2DE804081201D0DAC
    1    768 006001  6841601280000       34560000 86045DD9 0B77AB22144043701306F362DD09080906A040A040D05613397E85F3EAEF973B4AFA9427E961A976A9F41AEF75BDB0A94E67D59F574CEA0DE1ACADFB9A546FC4549DAD27D6A1BF74A6BC374F93A644A6942AE9A1B97CFE8695E3C3D35E956B8B62264D09EDBAE99F53534D52A84FDD527B6E1467EF9EC7F2DE7C4891201B6A85
    1    768 006001  6841635840000       34560000 B9C51F4A 0B777F6F144043701306F362DD090A0808A060208090561529854A957A4BC8BE84FA93EAEF953A75561BE7CADD217D4A9427D19FAA74F60FF9D31535279BB02F4E990E9E1A980E6C86B56A8553A17D5DD2A4C99D55D75A79EAA15872FA157B7095B6734E6DC5639D91535E14254FE6EF7CAA13E7EA9EC7F2DE80408120000277
    1    768 006001  6841670400000       34560000 64B0D2CF 0B77EB06144043701306F362DD09090808A0606060B05612BF54A5FB97F06B6B7BB1CBF2CE9D3D7EE6B6B7CA9F267CFA9B9AD575BF749A0FE0DEB1D8D79BF7AF56366EBAD6A20E4CF6B737D5D33A850D52D86FA94E7D0A7750E1AC42E9CD6B70D5BE43AB5C3849D33B416B5AA7EF9ED77CF6C39850DEC3F2DE8040812011DF4F
    1    768 006001  6841704960000       34560000 278069DA 0B778EAC144043701306F362DD0A0A0809A040408070561247A4F9F437CA9539AF46BC2AD4A1AA535ABBF4AE9CD77D0953F534A1C2534E0FF8B701525CBBAFD85636752AD2132B41AE942550D54F4C961C24CFA7427D0A77362B3F754ABEA8F09F9339AADC354495BDAB75D114EF9EDB7D4DD3A7B0DED6F2DE804081200BF043
    1    768 006001  6841739520000       34560000 76959C46 0B774B68144043701306F362DD07090907A0A06060B05613297CFA9577B4DED77CEAB3B4B6DD2A74E6BA5B6A9F5254FA8DB7D0D2C27D0A41DC5CC48BA99BB02F2E35CF05B1153F4339EDC7B5DF3E7CFABA97E9C6D2850B84CFA1444CEA1568E59609434A347B69A7D27181F3E554DCC2AF0A9AA5CE6025F2DE8040812011B441
    1    768 006001  6841774080000       34560000 B2A71D58 0B772A0F144043701306F362DD0A0A0908A0404060B056463DA50D4D37B5E8EF54FDCD27D5DF3E4CA69A9AF49ED68749FA64CA5FA64C9A0FF9845DF4ECBC212B4E39AEB7D0CBA56CEA1575E85F26A55A9A64CFD2C27E5B7750E1407CE756B870DB2643977C85689DA17CF77D2554B3437BAE1A674F6B5AF2DE80C183201DE9C8
    1    768 006001  6841808640000       34560000 C6147BD3 0B77466D144043701306F362DD09080806A06080A0D05613117EF93427E561A584F9FBE7CA5F43735DD527C9A93E7CFAB3E84FB53F4C9A03E18CADF4ECD6ABC288D9AEAB75D53B4CF5EDB86F9F3DD8E6BAA7CF9D3EA6F684B0F81342EA8EBAD1113A4B9AD6054EB5BDB50AE294D4A9C27CFA7967B5D525F2DE80408120197E00
    1    768 006001  6841843200000       34560000 053244D1 0B775BC41440437FF306F362DD0A070907A040A060B25645A67D0A1AA7692BBE7CF9F4E7EA92D27D59FC274F9CD2A895FA6534A0EB84FE0DE15D0092669BE3C32E7696BB56E1402335ED853112CE750AC1154AD2D2869A84B117927CE75705CBD53A73AAFC754FDCD6AD5DF427686B5B7E992C44A99D3AF2DE804081200CE693
    1    768 006001  6841877760000       34560000 A3FB9F4B 0B772E8B1440437FF306F362DD0B090808A0006080925614AF734DEC354F94D6AF0A1537B6A957735ABBE7D39F52A4FC8BEAEE9EBECD6E41608E4DFB5CD9AE481A3696AD70D5ADCEE925F5D0133A74F2DC35645F55DF4E84B0B09274FA955B90C9A0A5970575825B3E7B512BF4CD6BC2A5096119B5D53EF2DE804081201905BD
    1    768 006001  6841912320000       34560000 EF20ACBE 0B77114C1440437FF306F362DD09090907A0606060B25643BE84FA9A9AEF6BD2A4FA13E7EA6956A55D52A7B5DF2B54A613F72FA9484AF9DA60B4B1DA5ADBADAF4E235EBAD0E1A1AEF694284FD53AD55B3A9888613EAB228496E43F4CF9EDB8D11D267BAAB7076969BA7B5DF3F4B4E8EF7CF9F577E32BAAF2DE804081200AE010
    1    768 006001  6841946880000       34560000 5015D23D 0B77DE071440437FF306F362DD070A0808A0A04080925612C2A55ABBE54EA94742FA9A57E969BA4B5A96B7CFA13EA69D03E7CFA93E86EA1A49724DF39E0F30AA56875E9AF0D5A717B20D75495FBEA51D5264D49F467B1E773217BF4ABAB707B1D625739AD5B5EB1AA5A50DF428085556A54D33E7D39EDBF2DE804081200EABB4
    1    768 006001  6841981440000       34560000 C5DEE2C0 0B7760111440437FF306F362DD09060706A060C0A0D25643BF4CA6BBA74F9F527D09FA5A549F3EA54DFA17B4DCEA8EA9FA5AE96B5374EA4D74B6ADDA1A5AD73044869D6850DFBE75494BE883532A754AB5B4C99F3ECEAF74B221BA7CAA1BF7B0D5B5A6F6D7056D9CEED55DF534B4AB577D59FBE54A6BC1F2DE80408120066DD8
    1    768 006001  6842016000000       34560000 CF5F77FA 0B77C7FF1440437FF306F362DD0B060706A000C0A0D25614CE7E9932A74F953A7E9932584FA1527EE9F2A5CFA12A7506BBF4AFD4D74BAE1A5BE0EA9B9AD5E0E056E6C34BF71D2A7CF9D2652FDF52A50A9A988994E6A6A7819621A67CFAB6B88461A6735AFC77E39551AEF6BC44432B6FA5597BDA699F2AF2DE8040812009091E
    1    768 006001  6842050560000       34560000 D47EC4B9 0B776D661440437FF306F362DD09070706A060A0A0D25643BF535D73DB835F2A7CFD539A6E9CD67DAD5A57CF9F427CFAB52AEE9CBE8509D3438501329D6F6E431AFE93E86FDD3A754C8C1AF010A5B55ABBDAEFE7527C9B74D5E2264D59F57A4F9FBA7D070427E49D3A54B6BBF7B0DD427D49F577D49ED7F2DE844891200078C2
    1    768 006001  6842085120000       34560000 75ACD309 0B77B99D1440437FF306F362DD08060607A0A0C0C0D25614D6B09693B22FA1427D4A1A5AEB6A107D5DEC356A92BE7D5ABB9ACFA152D695D0D6C0FE93EB55ADD686FABC2D6E95BE7CFC86C22F96254CED12586E9F29AD5F744FE3D77B5EB567F0D33F74E5F5776E9D52AD4ABBAA4F9D57495DF577695D2AF2DE844891200991B8
    1    768 006001  6842119680000       34560000 C94D736A 0B7769591440437FF306F362DD05060707A0E0C0A0B256463DB5AD53E7CFD3257DA6DD3835A95754F9FA4AEFA9A57D4A14374975B9A6A9D270B75E956856E1AE5646C25A74D3A17E95EEB54A9FA9AEFAB44411DD527CA6755114D87CF6DBE86BA93F550AB5B7D110D27D49DBB494DF436B0D32B510A9ADF2DE84C993201A471C
    1    768 006001  6842154240000       34560000 1C0D6BED 0B7746E71440437FF306F362DD08080806A0A08080D2564FD2AEE73BA550DED77495F56AD5DF2AA35E93F4CD9129A3612D67D0DF39AD0DD2EBB8AA1437CFDF3E84FABBF554D3A17EE5D3E7D09FA9AD5E94EAD4D52EA35F74B6EDEC7CBAC3CB6BD4DB84FA3BE80E89257B5E1BD86FAB434B008B9CEAA93EF2DE85CB97201BB4CD
    1    768 006001  6842188800000       34560000 466D049B 0B77A12C144043701306F362DD04040706A10100C0D056424186FD2AA7CFA93AACFAC10AEA6BBE735ABBE54F9F427CFA93E7E969D31AA606DC7C9A142B5B0B4254A9FBB4CF69AA7EF6BBECBAB63B72F9D42A6F9D524B0B74EA6DD7AD6E1B9875D52F849A1A17E9934EA4FA9A67CFD4D7495E957864613AF2DE84489120056958
    1    768 006001  6842223360000       34560000 120E429F 0B77839D144043701306F362DD04060707A100C0A0D05643BF549C6BDB8969427EA61B97D5E8D8419DF3DB551CAA7CF75C34CE95267CF9D2DCAD5EAF57B497BF530D2C42C9953E7D4A9BDCEFA956A6A9DA6539D5A17CF774CFABD7AD1ADC42ABDF2A54A97D27EE9CD286FA953A4F95BDAD0A942A6A92D7F2DE844891201F5B1E
    1    768 006001  6842257920000       34560000 9A0061C2 0B777A94144043701306F362DD07070707A0A0A0A0B0564425D6F6BC34B0A13F4B69FA674A94D374F94E852A6B5B84EA9BA4C96B3F734E03F5AD5AB5C8CA64435B0D32752FD33B44E6BBE7B1E957A36E9A97EA9EC286FA76BB21CED5BE14354FC92E854D52654FD33A854A1BE54F6DD67CFE72A7B5A9BEF2DE83468D200386F6
    1    768 006001  6842292480000       34560000 EE4E947A 0B773E3B144043701306F362DD04080A06A1008040D05643D6AD0DD39B052C2554AA1537C9A725A6FA8D37D09F427E49F3E72FDD3E54A60657B95A142B5254BD86ADF16854DD29D895FBE84FA94286F9590AF09FD1B55E81B0EDD2AEBA33F5509F437CFC9267E99FA0A6F9FBE7CFA995A54D2D7534ABBDF2DE80408120195B92
s=2 n=0 o=0
mt=00000267DDEC8E80 n=3
    0  14848 004018  6841308474000       54054000 5A12FF62 00000100005FFFFBB8000000000001B58555571F80000000000001B2050B0ADC847F050C8080C8D9000000000000000000000000000000000000000000000000000001017A57299C3299D95D5C11BF0FB4630B68C30D533CE02BFDA822FE1F68D18B0C3460D18B161868CAD18B161868CAD189CD1861AA6794CF1BF0FB462CCC
    1    768 006001  6842327040000       34560000 6554587B 0B77B436144043701306F362DD06060706A0C0E0A0D05643BE7EF9F3DB0969AD84FA1B9D4FAB53749D2577D49D3E84F9F3EAEF5F537B5DD0DCAF0D2C2AD6A3C754AA1A5B0892D77E96B577D4A1577CFA152A56D53E74EB75382B6FCD0A4B9551A1BA5C9DD3F42FD53DA6FA1C17EFD4D69CFD52E735DD42F2DE84489120017AAD
s=2 n=0 o=0
005003:0000 Failed to save title 0 to file G:/title_ID-01.mkv
005004:0080 0 titles saved, 1 failed
dla7614
Post by dla7614 » Sat Feb 20, 2021 8:32 pm
I got this same error. I thought it might be something with the DVD writer I was using and tried to change the order of the titles I was recording to the DVD but always targeted the same title. I have a copy of version 1.12.2 but would need to have an activation code to be able to use that version. Can anyone give me the code for version 1.12.2?
Post by Woodstock » Sat Feb 20, 2021 9:08 pm
A version from July of 2018 probably won't accept a current beta key. A permanent key would work, but you're on your own trying to get the beta key to work.
MacChickenSamich
Post by MacChickenSamich » Sat Mar 13, 2021 5:25 pm
I was trying to rip the Young Guns DVD and encountered this error:
I found this thread and looked at several others, but couldn't find a fix. The disk was clean and I haven't had any issues like this before or after trying this one title.
Note, I tried without success on the previous version of MakeMKV and then upgraded to the new beta release v1.16.1 today (March 13th), but it still failed.
Then I decided to deselect the subtitles and give it another try. It worked! Apparently there was an issue with that lossy subtitle track, which was:
Subtitles CC -> Text English (Lossy conversion)
Posting just in case it helps someone else.
Post by mike admin » Sat Mar 13, 2021 6:12 pm
MacChickenSamich
Post by MacChickenSamich » Tue Mar 16, 2021 3:08 am
mike admin wrote: Sat Mar 13, 2021 6:12 pm Please do this, if you can - http://www.makemkv.com/onlinehelp/testdump.html
I captured the testdump for Young Guns and uploaded it to dropbox. I sent you an E-mail from DropBox when I shared the folder with you. Let me know if you received it.
Galwyrd
Post by Galwyrd » Sat Jul 03, 2021 6:24 am
MacChickenSamich wrote: Sat Mar 13, 2021 5:25 pm I was trying to rip the Young Guns DVD and encountered this error:
MacChickenSamich, THANK You! that worked. I got a Jerry Lewis collection for my Mother's Birthday and spent hours trying to get it to rip and as soon as I removed the Lossy Subtitles it just worked! Thank you for posting your solution!
Post by Woodstock » Sat Jul 03, 2021 2:07 pm
MacChickenSamich wrote: Sat Mar 13, 2021 5:25 pm Then I decided to deselect the subtitles and give it another try. It worked! Apparently there was an issue with that lossy subtitle track, which was:
It would seem this disk advertises that it has closed caption subtitles, but doesn't really. This is a problem on more than just the Mac.
crazyheartstrings
Post by crazyheartstrings » Wed Feb 09, 2022 1:02 pm
Woodstock wrote: Sat Jul 03, 2021 2:07 pm
Add another disc to this error list: Disc 3 from Ken Burns Jazz boxset (so far) directly from PBS.
Discs 1 & 2 ripped fine using manual mode which I have learned is the only way to go on Mr. Burn's work.
Disc 3: 4 attempts, 2 manual, 2 automated with lots of cleaning in between.
I knew I had read about this error but I couldn't seem to find it in the search.
7 more DVDs to go in this set should go much quicker without the "CC".
Thank You!
gary9872
Post by gary9872 » Sun May 29, 2022 7:06 pm
Thank you for post. I have the same problem with my Young Guns Disc.
Arch Linux (Rolling)
Drives:
DVDRAM GH24NSC0 Rev, LY00
BD-RE WH16NS4 Rev. 1
ocmyhome
Post by ocmyhome » Sat Jun 03, 2023 8:06 pm
This worked for me, thanks!
gixxerfool
Post by gixxerfool » Wed Aug 28, 2024 9:58 am
THANK YOU! This worked perfect. To Note The X-Files S06E12 wouldn't rip, all the rest on disc 3 were fine.
BrettTheRipper
Post by BrettTheRipper » Fri Dec 20, 2024 8:12 pm
MacChickenSamich wrote: Sat Mar 13, 2021 5:25 pm I decided to deselect the subtitles and give it another try. It worked! Apparently there was an issue with that lossy subtitle track, which was:
I know this is an old(ish) thread, but I just want to add my thanks and confirm that this solved a problem for me ripping an episode of Road to Avonlea (season 2, episode 4). Literally every other episode in the box set of the entire series ripped just fine.
I'd add that this error was distinctive from others I've encountered. Instead of the usual long read/error message/rinse/repeat cycle I've seen MakeMKV go through with other disks, it aborted the rip instantly once it generated the error message in this thread's title ("LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)"). I tried multiple times with several different drives but had no luck until I deselected the subtitles.
Again, thanks for the tip, MacChickenSamich; this has helped at least a few of us.
