Clash of the Titans (2010) UK
preserve
Post by preserve »
Disc Information
Label: CLASH_OF_THE_TITANS
Timestamp: 2010-06-08 10:57:15
Data capacity: 38.98 Gb
Disc type: BD-ROM
Number of layers: 2
Protection: AACS v16
Main Movie - playlist 100
Title information
Name: Clash of the Titans (English)
Source file name: 00100.mpls
Duration: 1:46:07
Chapters count: 17
Segment count: 14
Segment map: 1,25,26,27,28,29,30,31,32,33,34,35,36,37
File name: Clash of the Titans_t01_s00100.mkv
"Maximum Movie Mode" Picture-in-Picture Experience - playlist 101
Title information
Source file name: 00101.mpls
Duration: 1:48:01
Chapters count: 17
Segment count: 14
Segment map: 40,25,41,27,42,29,43,31,44,33,45,35,46,37
File name: Clash of the Titans_t02_s00101.mkv
The other two playlists match these, but with Japanese subtitle options.
AV Sync log with 1.15.4:
AV synchronization issues were found in file 'Clash of the Titans_t01_s00100.mkv' (title #2)
AV sync issue in stream 1 at 0:07:04.382 with duration of 1.333ms : encountered overlapping frame, audio skew is +1.708ms
AV sync issue in stream 1 at 0:17:27.379 with duration of 10.625ms : encountered overlapping frame, audio skew is +12.333ms
AV sync issue in stream 1 at 0:17:27.392 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +1.666ms
AV sync issue in stream 1 at 0:36:50.750 with duration of 0.125ms : encountered overlapping frame, audio skew is +1.791ms
AV sync issue in stream 1 at 0:49:18.872 with duration of 5.625ms : encountered overlapping frame, audio skew is +7.416ms
AV sync issue in stream 1 at 0:53:20.530 with duration of 5.916ms : encountered overlapping frame, audio skew is +13.333ms
AV sync issue in stream 1 at 0:53:20.544 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.666ms
AV sync issue in stream 1 at 0:57:31.531 with duration of 7.25ms : encountered overlapping frame, audio skew is +9.916ms
AV sync issue in stream 1 at 1:03:52.286 with duration of 1.958ms : encountered overlapping frame, audio skew is +11.875ms
AV sync issue in stream 1 at 1:03:52.298 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +1.208ms
AV sync issue in stream 1 at 1:23:10.694 with duration of 3.416ms : encountered overlapping frame, audio skew is +4.625ms
AV sync issue in stream 1 at 1:25:56.734 with duration of 7.125ms : encountered overlapping frame, audio skew is +11.75ms
AV sync issue in stream 1 at 1:25:56.746 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +1.083ms
AV sync issue in stream 1 at 1:30:08.319 with duration of 10ms : encountered overlapping frame, audio skew is +11.083ms
AV sync issue in stream 1 at 1:30:08.330 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.416ms
AV sync issue in stream 1 at 1:33:26.809 with duration of 6.041ms : encountered overlapping frame, audio skew is +6.458ms
AV sync issue in stream 1 at 1:35:43.571 with duration of 6.375ms : encountered overlapping frame, audio skew is +12.833ms
AV sync issue in stream 1 at 1:35:43.584 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.166ms
Using: ASUS BW-16D1HT 3.00
