MKV DoVi MEL or FEL details
Sammy135
#1 Post by Sammy135 » Sat Mar 06, 2021 12:17 am
Hi All,
Really sorry but new to all this!
Have just burned my 13 Hours UHD disk to MKV file to play on a Dune 4k pro II player - it is a FEL title and i want to know if i have burned a FEL file. Details below - i can see dvhe.07.06 but not sure if the Main 10@L5.1 tells you there is an enhancement layer and whether that is FEL or MEL?? Any help would be appreciated. Thanks
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2 h 24 min
Bit rate : 72.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.362
Stream size : 72.7 GiB (88%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Original source medium : Blu-ray
Sammy135
Re: MKV DoVi MEL or FEL details
#2 Post by Sammy135 » Sat Mar 13, 2021 12:51 am
Guys - any help at all on this?????
za.marcello
#3 Post by za.marcello » Sat Oct 11, 2025 8:25 pm
the only way , i have found to know , is to reload the mkv file produced by makemkv with makemkv , upon expanding the video track you will see fel or mel , mediainfo is just generic i think and doesnt tell u shit about FEL or MEL :D
