MKV DoVi MEL or FEL details
Sammy135
Post by Sammy135 »
Hi All,
Really sorry but new to all this!
Have just burned my 13 Hours UHD disk to MKV file to play on a Dune 4k pro II player - it is a FEL title and i want to know if i have burned a FEL file. Details below - i can see dvhe.07.06 but not sure if the Main 10@L5.1 tells you there is an enhancement layer and whether that is FEL or MEL?? Any help would be appreciated. Thanks
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2 h 24 min
Bit rate : 72.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.362
Stream size : 72.7 GiB (88%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Original source medium : Blu-ray
Sammy135
Re: MKV DoVi MEL or FEL details
Post by Sammy135 »
Guys - any help at all on this?????
za.marcello
Post by za.marcello »
the only way , i have found to know , is to reload the mkv file produced by makemkv with makemkv , upon expanding the video track you will see fel or mel , mediainfo is just generic i think and doesnt tell u shit about FEL or MEL :D
arstnortle
Post by arstnortle »
For those stumbling upon this post, you can use the makemkvcon cli program to determine if an .mkv file has an MEL or FEL enhancement layer. makemkvcon is included with the MakeMKV application and found in the MakeMKV application directory. An example on MacOS:
arstnortle@mac ~ % /path/to/makemkvcon --noscan info "/path/to/somefile.mkv"
produces output like:
Title  0
0 Video MpegH HEVC Main10@L5.1 (dvhe.07.06 BL+FEL+RPU)
1 Audio TrueHD Atmos
2 Audio Dolby Digital
3 Audio Dolby Digital
4 Audio Dolby Digital
5 Subtitles HDMV PGS Subtitles
6 Subtitles HDMV PGS Subtitles
7 Subtitles HDMV PGS Subtitles
The "--noscan" options prevents scanning optical drives. Other options and documentation can be found here:
https://www.makemkv.com/developers/usage.txt
and here:
https://bluray.beandog.org/makemkv/man/makemkvcon.html
