LG BH16NS55 FW 1.03 unable to over-flash
holunder2
#1 Post by holunder2 » Fri Mar 12, 2021 1:59 pm
Hi guys, got a new LG BD-RE BH16NS55 and wanted to flash the LibreDrive compatible firmware HL-DT-ST-BD-RE_BH16NS55-1.05-NM00400-212004211049.bin
My current firmware version is 1.03.
So, I’ve followed the guide using cmd as admin and it seemed to successfully flash the MK firmware (with "enc" command). But it somehow didn’t got applied? I made a screencast of this process.
First, my drive did not make a 'restart' noise after the flashing and the process was faster than in the tutorial video. Then after the flash, even after a complete system restart, my drive is still using the 1.03 firmware:
Revision: 1.03
Serienummer: KLWIB9G2100
Firmware-Datum: 2117-11-20 17:04
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 72
Harware support: Yes
Firmware support: No
Firmware version: 1.03
What did go wrong here?
Re: LG BH16NS55 FW 1.03 unable to over-flash
#2 Post by d00zah » Fri Mar 12, 2021 2:58 pm
"enc" is only required if the drive came w/ an encrypted FW (i.e. v1.05). & only for the 1st flash to non-encrypted FW. Since you appear to have started w/ v1.03, "enc" was never necessary.
holunder2
#3 Post by holunder2 » Fri Mar 12, 2021 5:37 pm
Thanks, got it working! :)
