File keeps playing after it reaches the timestamp
William Morris
Post by William Morris » Sun Mar 07, 2021 9:12 am
I've ripped off The Dick Van Dyke Show on Blu-ray, and there seems to be an error with the timestamp on some episodes. One episode shows 25:58 on the details pane, but when I play the file, it shows 25:29 as the timestamp, and it keeps playing after it reaches the timestamp. Is there anything I can do to fix this problem?
Re: File keeps playing after it reaches the timestamp
Post by Woodstock » Thu Mar 11, 2021 1:44 pm
That depends on what is causing it. One thing that has been mentioned in the past is if the audio track is not the same length as the video track.
I have not seen what you are describing, but I pretty much process everything I rip through handbrake before watching it through, and that would synchronize the track sizes.
William Morris
Post by William Morris » Sun Mar 14, 2021 5:27 am
Thanks for the reply. I have never seen this problem before either, and I’ve ripped a lot of discs. I’ll use Handbrake to see if it helps.
