Looking at buying LG WH16NS60
bradwiggo
#1 Post by bradwiggo » Wed Mar 10, 2021 6:14 pm
I'm looking at getting a LG WH16NS60 on eBay. Is it guaranteed to be able to be flashed with the firmware to allow it to rip 4k discs? I have read about the "drive platform" needing to be a certain one?
Re: Looking at buying LG WH16NS60
#2 Post by dcoke22 » Wed Mar 10, 2021 9:11 pm
Have you looked at the UHD Drives Guide? viewtopic.php?f=16&t=19634
bradwiggo
#3 Post by bradwiggo » Thu Mar 11, 2021 2:38 pm
yep that's where I found the bit about the drive platform.
"2. Drive Platform MT1959<Most important"
Are you guaranteed to get that platform if you buy one of these drives though? Do all new ones have it.
#4 Post by d00zah » Thu Mar 11, 2021 3:25 pm
Drives manufactured after ~Oct 2015 should have 'Drive Platform MT1959'. However, there's a small chance you could get a unit from "old stock", unless you specifically ask & can get that assurance from the seller, in advance. YMMV
Buying from one of the vendors here guarantees you a pre-flashed/tested drive... but you may not get the price you see on ebay.
bradwiggo
#5 Post by bradwiggo » Thu Mar 11, 2021 3:50 pm
If you can see the date on the drive and it's after 2015 does that mean it would be a guarantee, or is there still a chance it could be the wrong platform?
Also does this apply to the "40" as well as the "60"? (i.e. this one https://smile.amazon.co.uk/LG-Electroni ... 86&sr=8-10)
#6 Post by d00zah » Thu Mar 11, 2021 4:33 pm
LG drives. 2016+ (SVC NS50/51 on physical label) would be fine. As to "guarantee", that's between you & the specific seller... IF you ask in advance (& choose to believe them). If you require a worthwhile guarantee, the 'local' sellers are the logical choice. IMO asmcom (Robin IIRC?) in UK... on eBay, too.
