- Single layer DoVi track, taken from UHD Bluray with MakeMKV
- EL layer, (dvhe) taken from the same UHD and demuxed with ffmpeg into BL+EL
General
Complete name : S:\Temp\ΔTemp\_movie.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/mp42/dby1)
File size : 39.5 GiB
Duration : 2 h 15 min
Overall bit rate : 41.9 Mb/s
Encoded date : UTC 2021-03-08 09:03:48
Tagged date : UTC 2021-03-08 09:03:48
Video #1
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 41.1 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.206
Stream size : 38.8 GiB (98%)
Title : movie
Language : English
Default : Yes
Alternate group : 1
Encoded date : UTC 2021-03-08 07:55:54
Tagged date : UTC 2021-03-08 09:06:37
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 389 cd/m2
Codec configuration box : hvcC+dvcC+hvcE
Video #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : dvhe
Bit rate : 792 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.016
Stream size : 765 MiB (2%)
Language : English
Default : No
Alternate group : 1
The effect is:
- nVidia SHIELD Pro 2019 plays it as Dolby Vision but it is stubborn to play for some reason the EL track so you just got Dolby Vision EL layer which look really strange
- Plex on C9 falls back into HDR - maybe there is too many dvhe streams in this MP4 file
