Rob9000
Post by Rob9000 »
Here is the media info for the mp4 that plays back in DV on my C9:
General
Complete name : *****.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/dby1/isom)
File size : 63.7 GiB
Duration : 3 h 2 min
Overall bit rate : 50.0 Mb/s
Encoded date : UTC 2021-03-03 15:24:56
Tagged date : UTC 2021-03-03 15:24:56
Video #1
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 49.5 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.249
Stream size : 63.0 GiB (99%)
Default : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 801 cd/m2
Maximum Frame-Average Light Level : 188 cd/m2
Codec configuration box : hvcC
Video #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 69.4 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.001
Stream size : 90.6 MiB (0%)
Default : No
Codec configuration box : hvcC+dvcC
Audio
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : ac-3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 585 MiB (1%)
Language : English
Service kind : Complete Main
Default : No
Rob9000 wrote:
Mon Mar 08, 2021 5:57 pm
General
Format : MPEG-4
Video #1
Format : HEVC
Codec ID : hev1
Color space : YUV
Bit depth : 10 bits
Default : No
Video #2
Format : HEVC
Codec ID : dvhe
Color space : YUV
Bit depth : 10 bits
Default : No
Audio
Format : AC-3
Codec ID : ac-3
Bit rate : 448 kb/s
Language : English
Default : No
That's because your file is already correct. His file had both layers as 'hev1' where the EL should be 'dvhe', thus the reason he changed it in hex editor.
Rob9000
Post by Rob9000 »
I see now. Thanks
NiCE77
Post by NiCE77 »
I tried the new Ugoos 0.40 fw mod on Minix and from now on just use Plex, DV playback is perfect from STDL MEL/FEL ts, mp4 and mkv too.
NiCE77 wrote:
Tue Mar 09, 2021 3:43 pm
What about the AM6 plus ? still won't trigger DV with MKV files ?
I ordered one btw, should get it by March 16th according to the tracking number.
NiCE77
Post by NiCE77 »
RESET_9999 wrote:
Tue Mar 09, 2021 5:10 pm
AM6 Plus with 0.40 fw triggers DV with MKV files, same as Minix.
bobbymkV
Post by bobbymkV »
You think it would be safe to assume that the Kodi DV builds would work like they do on the Shield? I need the ability to transcode DTS audio (thanks Sonos).
NiCE77 wrote:
Tue Mar 09, 2021 5:13 pm
ha right! I mixed up what works and what doesn't work...
so it's lossless audio that doesn't work on plex but it works on kodi.
hepe9
Post by hepe9 »
RESET_9999 wrote:
Sun Feb 21, 2021 3:19 pm
yossSP wrote:
Sun Feb 21, 2021 3:20 am
RESET_9999 wrote:
Wed Feb 17, 2021 8:27 pm
He has the HDfury Vertex which can tell if it's lldv or tv-led DV.
https://www.youtube.com/watch?v=e_a77zJTrO4
Ok thanks, well as far as I know, LLDV if it's well made doesn't have to be worst than TV-LED.
The quality I observe in FEL files playback is really good, but I don't have any reference to compare with.
Watch the youtube video I posted. LLDV is confirmed to be worse quality than TV-LED DV. And all the players have the same DV SDK engine, therefore they are all affected by that.
Stacey Spears goes even further and says that LLDV is worse than HDR10.
Very interesting post, but Stacey Spears doesn't say LLDV is worse than HDR, at least in that post.
You who have the x700 and make good captures and comparisons can prove it, and maybe you are right
Edit: I found a post from a few days ago from Stacey Spears where he says that DV sucks in BD and that HDR is better
hepe9 wrote:
Tue Mar 09, 2021 6:24 pm
Interesting! I guess he came to that conclusion after testing the new DV pattern from his upcoming Spears and Munsil UHD bluray disc.
I don't really know about chroma upsampling nor ringing and I never really compared with LLDV but AFAIK, TV-LED DV on my setup (x700 + C8) looks much better and brighter than static HDR10 (better shadow details and more pop).
I will definitely check out the new DV test pattern when the disc is out.
some DV vs HDR10 examples made with my camera...
Spears and munsil: https://screenshotcomparison.com/compar ... p?id=10593
WandaVision: https://screenshotcomparison.com/comparison/11817
Sonic: https://screenshotcomparison.com/comparison.php?id=2605
pitch black: https://screenshotcomparison.com/comparison/11797
little things: https://screenshotcomparison.com/compar ... p?id=10640
WW: https://screenshotcomparison.com/comparison.php?id=9412
Post by shawnc22 »
Can you give this sample from saving private ryan a try and see if you notice any flickering throughout?
https://mega.nz/file/ECAA0DwZ#K8yxC-GMU ... coHzQk-6YQ
HarperVision
Post by HarperVision »
It isn’t LLDV nor Dolby Vision that suck. It is the Oppo. It has a chroma bug that most likely is related to the same well known one that reduces BT2020 colors to Rec709 when tone mapping HDR to SDR, which in my humble opinion is absolutely ludicrous.
Both Vincent and Stacey are wrong. Their testing is flawed and they’re passing this misinformation across the web. They didn’t bother to to test with a different UHD Bluray player. I did with comparisons between the Oppo 203, Panasonic UB820, Sony X700 and Sony X800M2, in which the X800M2 performed best in the end and had no such color issues.
I reported this a long time ago. I am the one to discover the LLDV/Dolby Vision trick to play DV on HDR10 only devices. I’ve been extensively testing and experimenting for nearly two years on a nightly basis. Early on when I was doing these tests I was wondering why the Oppo looked so pale in comparison. The Sony was clearly the best. The AppleTV also does an amazing job with DolbyVision/LLDV.
Post by Manixx2020beyound »
RESET_9999 wrote:
Tue Mar 09, 2021 7:54 pm
Same here on my end, but hdr10 saturation on blacks being crushed / static meta is the only problem on hdr10.
Some movies do look better in hdr10 even in static mata
But hdr10 to LLDV improves that, in theory
I guess baced on what he shoots with camera hdr, is minimized by the dv bd authoring process.
The decoded
LLDV capture does not go true the same 2nd dv processing when received by capturing Monitor so the LLDV picture is not double processed 1st internally & then when the same LLDV signal hits your tv.
I guess if movies wore shot in DV instead of hdr10 12 to 18 stops of dynamic range.
Dv is just lighting on top a hdr image regulated by the Rpu, from a raw 12/16bit tiff.
What if the image had the correct uncrushed blacks to begin with ??
The process is kind of flawed dv was ment to improve hdr10
Why didn’t they just improve hdr10 specifically on its own.
It’s like upscaling data that’s already flawed
Some will look better & some will look worse that the results we all been getting to some degree.
I can’t speak on the oppo
But most of my devices I tested LLDV / rgb8DV looks identical or close to the same.
Not that huge variance we saw on Vincent video.
Apple TV LLDV colors are slightly off (depending on firmware your on)
Compared to the shield tv. Profile 5 movies
I would like to do a wonder vision ep9 test LLDV
Apple TV , shield tv, dune vision ,x700,google chrome cast,Amazon fire stick.
X700 & dune vision will be using the real web.dl
All 4 other devices will be streaming from Disney.
A DV rgb8 screenshot would look nice as well. @reset9999
If the ugoos works really well I may get that & the minix for testing.
But I’ll wait til other folks report on playback
Last edited by Manixx2020beyound on Wed Mar 10, 2021 1:22 am, edited 3 times in total.
Manixx2020beyound wrote:
Tue Mar 09, 2021 9:04 pm
I would like to do a WandaVision ep9 test LLDV
+1 :)
dysprosium
Post by dysprosium »
shawnc22 wrote:
Tue Mar 09, 2021 8:29 pm
ragico has tested Saving Private Ryan already on the Ugoos AM6 Plus (fw 0.4); I assume the result is the same on the Minix Neo U22-XJ on the same firmware.
