I have PBS' Endeavour Season 7. There are two blue-ray disks with Eps 1 and 2 on Disc 1 and 3 on Disc 2.
MakeMKV reports 988 titles on disk 1. There seems to be two general types, one 5 chapters and 48 mins long and one 9 chapters and 90 mins long. I know that each eps is approx 90 mins long. I have no idea what the 48 min eps is.
They seem to be duplicates of each other ... lots and lots of them. I can't rip them all (who has that type of disc space). Can I rip the first 2ish minutes of all of them to see which one is Eps 1 and which one is Eps 2?
Rip first 2-3 minutes of each track
Re: Rip first 2-3 minutes of each track
Use the vlc integration and watch the playlists no need to rip
Other folks have been figuring out the correct segment maps for the three episodes.
viewtopic.php?f=8&t=23357
I am intrigued by this - Can you explain how to use the vlc integration?Billycar11 wrote: ↑Tue Mar 09, 2021 11:45 pmUse the vlc integration and watch the playlists no need to rip
In makemkv a setting go to integration tab and check vlcRob9000 wrote: ↑Wed Mar 10, 2021 6:26 pmI am intrigued by this - Can you explain how to use the vlc integration?Billycar11 wrote: ↑Tue Mar 09, 2021 11:45 pmUse the vlc integration and watch the playlists no need to rip
Then go in vlc and select open disc Blu-ray and no menus if you don't have java.
