bedders
#4591 Post by bedders » Sat Mar 06, 2021 10:35 am
I have a question about profile 7 DV and MakeMKV. Am I right in thinking that if a FEL UHD disc has been ripped with MakeMKV then the it generates a single video track and the enhancement layer 1080p track from the disc is somehow interleaved along with the main video track?
If this is the case, how does one tell from the resulting MKV that it contains the enhancement layer since MediaInfo will show only a single 2160p track?
PS sounds like the Ugoos AM6 Plus is the way to go for DV playback. Ordered one today :)
juzer7
#4592 Post by juzer7 » Sat Mar 06, 2021 2:43 pm
MastaG wrote:
Fri Apr 03, 2020 10:36 pm
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.09, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
But for me it does not play at all.. all I get is a black screen and a spinner, both in Emby and from usb disk using the builtin mediaplayer.
Something wrong with the above steps or commands?
Any help would be nice :)
Here is HELP :-)
I googled for the last few hours and I could not find an answer to the same question. I muxed the BL and EL video tracks with the command:
mp4muxer --dv-profile 7 -i BL.hevc -i EL.hevc --media-lang eng --output-file BL+EL.mp4
And for me the movie on my LG C9 was also not playing, showing only the "spinner" all the time. After some investigation I found that the issue might be here. After muxing the tracks into one MP4 file: BL+EL.mp4 - the EL track (2nd one) was described as:
Codec ID                                 : hev1
And I found that in order for a Dolby Vision MP4 to play correctly on LG C9 it has to be like this:
So I needed to find a way to change hev1 into dvhe inside the EL video track inside the MP4 container.
I could not figure out any command or switch in mp4muxer or m4box to do so (there might be one) so I decided to go a different way.
I downloaded HxD Editor
https://mh-nexus.de/en/hxd/
Then I opened the BL+EL.mp4 file and I went to menu Search -> Find -> Search for: "hev1" + Case sensitive (checked).
Inside an MP4 file without audio tracks (could be the same inside a file with audio tracks) it was the 2nd search result.
So after I found the first "hev1" occurance (line 01E0) I looked for the 2nd one "hev1" (F3 - Search next) which was line 00023AF00. My guess was that the video streams were written in the MP4 file in the sequence: BL and only then the 2nd one is EL.
So then I just overwrote the 2nd occurance of "hev1" into "dvhe".
After that I just saved the file File -> Save. HxD Editor will create a backup for you so you don't need to backup the file before in case something goes wrong.
After opening Plex on LG C9 voila... Dolby Vision! No more spinning wheel.
And in the MediaInfo I found:
I hope someone will find it helpful.
Xtremux
#4593 Post by Xtremux » Sat Mar 06, 2021 3:04 pm
First of all, greet everyone and thank the work and effort made so that we can reproduce DV. I would like to know, if possible, that someone explain step by step, how to create a m2ts or ts that maintains the two layers of DV in one file and is playable on a Lg CX tv. I have read almost 300 pages, but the information is confusing at times, and somewhat difficult to understand at certain points. If someone would be so kind to describe the steps and share the necessary tools for the job, since these also change and are constantly updated, to know the necessary versions of each program. Greetings and thanks again. Sorry for my terrible English.
quietvoid
#4594 Post by quietvoid » Sun Mar 07, 2021 6:30 am
Mentioned a while back but you could have just used the 2018 version, they just removed flagging as Dolby Vision for dual layer.
See https://github.com/quietvoid/dlb_mp4bas ... a64a6a00a5
XTrojan
#4595 Post by XTrojan » Sun Mar 07, 2021 7:29 am
Is that the only file one has to revert and then it will work for LG CX with FEL and all that?
Also, I can't find a 2018 version, seems they routinely updated it without versions :<
quietvoid
#4596 Post by quietvoid » Sun Mar 07, 2021 8:41 pm
https://github.com/DolbyLaboratories/dl ... a4eabd/bin
I don't have a CX but with a C8 it is the only required change.
#4597 Post by shawnc22 » Mon Mar 08, 2021 1:21 am
From all the reports so far, it looks like the CX does not have support for FEL regardless of what container you mux your video in.
juzer7
#4598 Post by juzer7 » Mon Mar 08, 2021 9:35 am
CX does NOT support dual layer DoVi MP4 :oops:
I got 3 LG OLEDs in my family.
  • On B8 and C9 dual layer DoVi MP4 plays FINE.
  • On BX dual layer DoVi MP4 does NOT play. It falls back into HDR.
juzer7
#4599 Post by juzer7 » Mon Mar 08, 2021 9:40 am
Hi, as I was curious I made one more test. I tried to mux into MP4:
  • Single layer DoVi track, taken from UHD Bluray with MakeMKV
  • EL layer, (dvhe) taken from the same UHD and demuxed with ffmpeg into BL+EL
Then I muxed them with mp4muxer into one MP4 file and I got this
General
Complete name                            : S:\Temp\ΔTemp\_movie.mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (isom/mp42/dby1)
File size                                : 39.5 GiB
Duration                                 : 2 h 15 min
Overall bit rate                         : 41.9 Mb/s
Encoded date                             : UTC 2021-03-08 09:03:48
Tagged date                              : UTC 2021-03-08 09:03:48
Video #1
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 41.1 Mb/s
Bits/(Pixel*Frame)                       : 0.206
Stream size                              : 38.8 GiB (98%)
Title                                    : movie
Encoded date                             : UTC 2021-03-08 07:55:54
Tagged date                              : UTC 2021-03-08 09:06:37
Mastering display luminance              : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Frame-Average Light Level        : 389 cd/m2
Codec configuration box                  : hvcC+dvcC+hvcE
Video #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 792 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.016
Stream size                              : 765 MiB (2%)
I was curious if this can play at all :D :lol:
The effect is:
  • nVidia SHIELD Pro 2019 plays it as Dolby Vision but it is stubborn to play for some reason the EL track so you just got Dolby Vision EL layer which look really strange
  • Plex on C9 falls back into HDR - maybe there is too many dvhe streams in this MP4 file
Rob9000
#4600 Post by Rob9000 » Mon Mar 08, 2021 5:37 pm
Video
Codec ID                                 : hev1
Here is HELP :-)
Codec ID                                 : hev1
Thanks for this. But it's curious. I have a C9 and have been muxing DV MP4 using the same program. The codec ID is hev1 and the 3 muxes i have done so far (Hobbit trilogy) play in DV just fine on my C9 via Plex.
Rob9000
#4601 Post by Rob9000 » Mon Mar 08, 2021 5:57 pm
Here is the media info for the mp4 that plays back in DV on my C9:
General
Complete name : *****.mp4
Format : MPEG-4
Codec ID : mp42 (mp42/dby1/isom)
File size : 63.7 GiB
Duration : 3 h 2 min
Overall bit rate : 50.0 Mb/s
Encoded date : UTC 2021-03-03 15:24:56
Tagged date : UTC 2021-03-03 15:24:56
Video #1
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Bit rate : 49.5 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.249
Stream size : 63.0 GiB (99%)
Default : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 801 cd/m2
Maximum Frame-Average Light Level : 188 cd/m2
Video #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 69.4 kb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.001
Stream size : 90.6 MiB (0%)
Default : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : ac-3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 585 MiB (1%)
Language : English
Service kind : Complete Main
Default : No
#4602 Post by MartyMcNuts » Mon Mar 08, 2021 11:22 pm
General
Format : MPEG-4
Video #1
Format : HEVC
Codec ID : hev1
Color space : YUV
Bit depth : 10 bits
Default : No
Video #2
Format : HEVC
Codec ID : dvhe
Color space : YUV
Bit depth : 10 bits
Default : No
Audio
Format : AC-3
Codec ID : ac-3
Bit rate : 448 kb/s
Language : English
Default : No
That's because your file is already correct. His file had both layers as 'hev1' where the EL should be 'dvhe', thus the reason he changed it in hex editor.
Rob9000
#4603 Post by Rob9000 » Tue Mar 09, 2021 10:35 am
I see now. Thanks
NiCE77
#4604 Post by NiCE77 » Tue Mar 09, 2021 3:43 pm
I tried the new Ugoos 0.40 fw mod on Minix and from now on just use Plex, DV playback is perfect from STDL MEL/FEL ts, mp4 and mkv too.
#4605 Post by RESET_9999 » Tue Mar 09, 2021 5:10 pm
What about the AM6 plus ? still won't trigger DV with MKV files ?
I ordered one btw, should get it by March 16th according to the tracking number.
