FLAC Audio
DavidW
FLAC Audio
Post by DavidW »
I've been an occasional user of Make MKV for my ~30 DVD and BD discs that I have. Most of my collection are audio files and those of a DVD/BD origin are concert or music documentaries. My goal with Make MKV is to record the best audio (and video) when I rip DVD/BDs.
When I rip or download audio from CDs and other sources, I always do so as uncompressed FLAC files. I thought I was doing the same with the DVD/BDs but now see that under Preferences => Advanced, there is a setting for FLAC that is different from the default. What is the audio codec of "Default"?
Thanks.
Screen Shot 2021-03-08 at 6.32.14 AM.png (124.15 KiB) Viewed 16654 times
DavidW
Re: FLAC Audio
Post by DavidW »
An update-
I went in and changed "Default" to "FLAC" and re-ripped the same disc. Surprisingly, the size of the disc (in GBs) was reduced. I would have thought if the codec went from AAC (or whatever the default is) to FLAC, the overall size would increase, and could increase dramatically.
The image on the right (created on March 5) was ripped with the default, and the image on the left (created on March 9) was ripped with FLAC:
Screen Shot 2021-03-08 at 8.16.48 AM.png (501.59 KiB) Viewed 16650 times
Re: FLAC Audio
The default is to pass through the audio in the same format it is on the disk; DTS-HD MA on disk is copied to DTS-HD MA in the MKV file. You can also get the "base" DTS audio copied out of the lossless track (my profile is set up to select it), for compatibility purposes.
By converting to FLAC, you get one audio track instead of (up to) two per on-disk format.
Re: FLAC Audio
There's a tool called MediaInfo (https://mediaarea.net/en/MediaInfo) that's probably easiest to install on MacOS using Homebrew (https://brew.sh) that'll tell you all sorts of details about your media files.
In terminal, a command like this:
mediainfo path/to/movie.mkv
will show you details about the file. Here's a subset of the audio from one.
Audio #1
Bit rate                                 : 3 810 kb/s
Maximum bit rate                         : 7 158 kb/s
Stream size                              : 3.17 GiB (5%)
Audio #2
Codec ID                                 : A_AC3
Stream size                              : 381 MiB (1%)
Audio #1 is the lossless TrueHD audio track and audio #2 is the Dolby Digital 'core' of that TrueHD track. My home theater system can't process TrueHD or DTS-MA tracks, but it can process lossless FLAC, so I use the same functionality you discovered to also rip a version with FLAC instead.
Audio #1
Format                                   : FLAC
Format/Info                              : Free Lossless Audio Codec
Codec ID                                 : A_FLAC
Bit rate                                 : 2 697 kb/s
Channel layout                           : L R C LFE Lb Rb Ls Rs
Frame rate                               : 10.417 FPS (4608 SPF)
Stream size                              : 2.24 GiB (3%)
Writing library                          : MakeMKV v1.15.3 darwin(x64-release)
That's the same movie, but you can see that the FLAC version of the TrueHD audio track is only 2.24 GiB vs. 3.17 GiB in the TrueHD version.
You can change with audio profile MakeMKV uses on a per rip basis by selecting the desired profile in the dropdown box on the right side of the window, just under the MakeMKV button.
