Any idea when MakeMKV can be purchased ?
johnman
Post by johnman »
http://www.makemkv.com/buy/ says that due to some technical issues, MakeMKV can't be purchased at the moment.
I'm fine using the current beta key as suggested on that page but I was just wondering whether there's any timeframe for when purchases can be made again ? For me, the purchase of a registration key is the final step in setting everything up and I'm keen to get it done (and also show some support for the MakeMKV team).
On that point, thank you very much to mike admin and the rest of his team for MakeMKV and the "MK" firmware and also everyone on this forum for all the advice. After I laid the groundwork by reading carefully this forum, everything for me went very smoothly.
I bought a LG BH16NS40 in an OWC Mercury Pro enclosure. I opened it up to confirm that it's at least SVC NS50 and it was SVC NS51 and had version 1.03 of the official firmware.
On my Mac, I installed MakeMKV and also downloaded sdf.bin and the most recent MK firmware for a LG BH16NS60 (version 1.02). I ran sdftool on the command line to change in one step from the official firmware to the MK firmware. Done!
Thank you again to everyone.
Re: Any idea when MakeMKV can be purchased ?
Post by mike admin »
johnman wrote: Sun Mar 07, 2021 11:48 am http://www.makemkv.com/buy/ says that due to some technical issues, MakeMKV can't be purchased at the moment.
Hopefully soon :) It is really an ugly technical issue that will be solved eventually.
JudyWhite
Post by JudyWhite »
Do you have any idea what the problem is? If I purchase one license, can I run two Docker containers with one license .
gfliger51
Post by gfliger51 »
I have the same concern. I just checked - the trial key is due to expire on March 31st. That's six days from today. Possibly a new trial key will be issued by then if the technical issue isn't resolved?
New beta key will be issued regardless, just maybe not on the 31st.
More information can be found in the FAQ about BETA and PERMANENT keys.
