MKVToolNix can't join LOTR UHD parts
ContinuousPalace
Post by ContinuousPalace » Mon Jan 25, 2021 8:28 pm
The Lord of the Rings Extended Edition discs split each movie into two parts. With the Blu-ray edition, I used MKVToolNix GUI to merge the two parts. But when I try with the UHD edition, I'm getting a "Appending tracks of this type is not supported." error.
Here's what I'm doing, just in case I'm somehow doing it wrong for UHD. (It has been a few years since I merged my Blu-ray parts and I can't find my Bly-ray movies, so maybe I'm just remember how to use MKVToolNix wrong...)
1. From the Multiplexer icon under the Input tab, drag part 1 of the movie to the source files box
2. Right-click part 1 in the Input box and choose "Append files"
3. Choose part 2 from the File Explorer.
4. Click Start multiplexing
After about a second, I get an error in my logs: "Appending tracks of this type is not supported." (I've also attached the "Normal output" as a file here.)
As far as I can tell, MKVToolNix does support UHD. At least, there don't seem to be any sites claiming that it doesn't. And I doubt that LOTR has something crazy going on.
Any idea what I'm doing wrong or where to look next?
merge lotr log.txt
normal output
(14.6 KiB) Downloaded 731 times
Re: MKVToolNix can't join LOTR UHD parts
Post by dcoke22 » Tue Jan 26, 2021 12:03 am
https://www.makemkv.com/forum/viewtopic ... 45#p100573
Folks in that thread claimed to be able to merge the extended editions of LotR UHDs.
ChisumMP
Post by ChisumMP » Wed Jan 27, 2021 9:56 am
MKVToolNix cannot join files containing flac streams, therefore "Appending tracks of this type is not supported". Your log shows at least one flac stream.
Chetwood
Post by Chetwood » Thu Jan 28, 2021 7:23 am
So let me get this straight, the LOTR extended editions are even too large for one UHD disk?
ChisumMP
Post by ChisumMP » Thu Jan 28, 2021 2:34 pm
Yes, same with "Lawrence of Arabia" and "Gandhi" 4k's.
necrosis
Post by necrosis » Sun Feb 07, 2021 1:03 am
Has LOTR ever been on one disk?
liechsowagan
Post by liechsowagan » Sat Mar 06, 2021 8:15 pm
necrosis wrote: Sun Feb 07, 2021 1:03 am Has LOTR ever been on one disk?
The Theatrical Editions, yes. The Extended Editions, not to my knowledge.
I own the DVD "bound book" and UHD editions of LOTR, and the UHD editions of The Hobbit. The UHD Editions include Theatrical and Extended Editions separately.
For the LOTR trilogy, there are 3 UHD discs for each title; 1 for Theatrical, 2 for Extended.
The Hobbit UHD Extended Editions fit on a single disc, so there are only two discs per title.
PC
-- Threadripper 3960X (24C/48Th @ 3.8 GHz)
-- 256 GB DDR4 3600
-- RTX 3080
-- Win 11 Pro
Software
-- MakeMKV v1.16.5
-- ProcMon v3.70
-- VLC v3.0.16
External Drives:
-- WH14NS40 (1.03 Stock)
-- WH16NS60 (1.02 Patched)
-- OWC Mercury Pro Cases
